plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2018, 02:36 AM   #1
aand74
Belgium
aand74 is offline
Filtering noise from signal
I know there are a lot of less or more complicated filters,
but if you only choose between moving average filter, and first order filter,
which filter do you use when, what are the advantages, disadvantages?
When should you switch from first order filter to second or higher order filter?
Old February 7th, 2018, 08:29 AM   #2
daba
United Kingdom
daba is offline
daba's Avatar
I guess there's many more types of filtering algorithm that I've never even heard of, but I also guess that the better the filtering, the more complex it will be, and hence more computational power will be needed. It most likely is a trade-off situation between effectiveness and cost.
I'm sure Peter will have something to say on this when he sees it.
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old February 7th, 2018, 08:34 AM   #3
Mispeld
United States
Mispeld is offline
Mispeld's Avatar
First Order:
Adv - Easy to implement, easy to model, minimal program memory req'd
Disadv - "Flier" data takes a long time to settle out (i.e., infinite impulse response), may require long lag time to achieve desired filter performance, potentially affecting feedback control performance.
Moving Average:
Adv - Can attenuated a specific frequency if "noise" (i.e., undesirable signal component) is known occur at that frequency, affect of "flier" data is gone after the moving average time base.
Disadv - Memory requirements and programming complexity, potential start-up time.
Higher Order (e.g., Butterworth) - can get better performance - noise reduction without phase shift - with modest increase in programming complexity.
Old February 7th, 2018, 08:59 AM   #4
daba
United Kingdom
daba is offline
daba's Avatar
I've got an Arduino project in the late stages of development for a Radio Control FPV receiving station that tracks the flying model.
It uses the RSSI (Received Signal Strength Indicator) off 3 receivers to determine the direction to point the antennae.
RSSI values can be affected by so many things, and a simple filtering algorithm wouldn't cut it.
I'm experimenting with Kalman filtering, and getting great results so far. Field trials (when the weather gets a bit warmer) to follow.
Kalman filtering (the cheap and cheerful explanation) looks at each "sample", and basically assigns a "confidence vote" to it, by comparing it to previous samples. It effectively only uses a proportion of the change to enter the filter, depending on how confident the algorithm thought the sample was.
It appears to be working well for filtering out the sort of things that can affect radio signals, noise, multi-path reflections, blinding, etc.
__________________
a-b train ltd.
www.abtrain.co.uk
tel: 07506 73 9999
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Grounding shield of 4-20mA signal adds noise? kolyur LIVE PLC Questions And Answers 22 August 6th, 2014 01:46 PM
Filtering Analog Signal dbh6 LIVE PLC Questions And Answers 23 April 9th, 2013 02:03 PM
Analog signal filtering question escoplcguy LIVE PLC Questions And Answers 11 March 30th, 2011 06:31 PM
Analog signal filtering Plc_User LIVE PLC Questions And Answers 4 July 20th, 2006 11:46 AM
how do I 'queue' machines using PLC & relays hickman LIVE PLC Questions And Answers 42 September 2nd, 2003 10:16 PM
