plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2018, 02:44 PM   #1
celichi
Canada
celichi is offline
celichi's Avatar
Ethernet/IP IO
Hello Everybody,
I was wondering if anyone here could help me with an idea.
I need to sound a small horn, max 72db.
24VDC, 20mA = 0.5 watts give or take.
Ideally, I would have an Ethernet/IP horn that I could turn on from a Compact Logix PLC.
Right now I am running cable for the horn and cable for the ethernet, would be amazing solution to be able to do both over ethernet.
Best regards to all!
Paul
Old February 7th, 2018, 03:01 PM   #2
damica1
United States
damica1 is offline
Not sure I understand your setup, BUT.
So if your horn was wired 24vdc all the time with an "Ethernet Controlled Relay"?
You just then want to energize relay from ethernet? Is this what your trying to do?
If so - this would work for you.
https://store.ncd.io/product/etherne...t-relay-2-way/
__________________
David M. Camp
Unlocking the power of IOT in Oil & Gas!
Old February 7th, 2018, 03:11 PM   #3
tarik1978
Morocco
tarik1978 is offline
yes you can If your switch has a PoE built in if not you can use a PoE injector
Old February 7th, 2018, 04:13 PM   #4
celichi
Canada
celichi is offline
celichi's Avatar
Sorry for the confusion. Currently we run a 2 wire cable direct back to the Main Control Panel (under 100 m) to a relay contact. The PLC drive the relay directly, no Ethernet.
My though would be to eliminate the PLC output point, relay and 100m of running cable. We have to pull an Ethernet cable for the Maple HMI, so I would like to eliminate the hardwired circuit to the horn mounted beside the smaller remote HMI.
Yes, I would like to energize a relay from a Compact Logix PLC.
Old February 7th, 2018, 04:14 PM   #5
celichi
Canada
celichi is offline
celichi's Avatar
Quote:
Yes, no problem with adding an injector, but trying to source a horn or even a relay that can be controlled from a Compact Logix PLC has been the issue.
I have looked at Point IO, but that is overkill, I just need one output.
Old February 7th, 2018, 04:56 PM   #6
GeoffC
Australia
GeoffC is offline
GeoffC's Avatar
Have a look at the Turck Fen20
http://pdb2.turck.de/en/DE/products/...0128730002003a
__________________
Geoff C
______________________________________
Old February 7th, 2018, 05:56 PM   #7
celichi
Canada
celichi is offline
celichi's Avatar
Quote:
Originally Posted by GeoffC View Post
This forum and the people on it are the best, amazing!
Thank you, exactly what I was looking for, nice size, minimal cost.
Old February 7th, 2018, 06:37 PM   #8
ASF
Australia
ASF is offline
Just to clarify - you'll still need a 24VDC supply for this, it's not POE.
Although, if I understand correctly - you currently have two wires up there which power an existing siren, and you want to re-purpose those two wires for a 24VDC supply to the HMI (and also, this I/O module). Then the only new cable you need to run is an ethernet cable, you don't need to run another two-core for the siren. Have I read you right?
A nice bonus to have embedded switch on the I/O module too - saves the cost of a switch or a second ethernet cable to the HMI!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ControlLogix Redundancy Ethernet/IP IO Configuration Popo Karimu LIVE PLC Questions And Answers 7 April 13th, 2016 08:51 AM
Balluff EtherNet/IP IO chintankAne LIVE PLC Questions And Answers 1 June 26th, 2015 01:22 AM
CompactLogix to Remote IO module error jeffy LIVE PLC Questions And Answers 7 September 8th, 2011 03:18 AM
FLEX IO with ControlLogix via EtherNet/IP OleksandrKurdydyk LIVE PLC Questions And Answers 4 February 14th, 2011 08:44 AM
Omron Ethernet/IP to AB Point IO AndrewY LIVE PLC Questions And Answers 1 August 26th, 2009 08:17 AM
