plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 7th, 2018, 06:44 PM   #1
Zlinger
United States
Zlinger is offline
Nema 4 bulkhead connector?
I have to pass some poly tube through the side of a control panel and maintain a Nema 4 rating. I have used bulkhead connectors many times before without having to worry about weatherproofing. It doesn't seem that any bulkhead connectors I have found are Nema 4. Anyone know of any? I have looked at Roxtec's stuff, but I am hoping to find a normal bulkhead connector with a gasket. Any help is greatly appreciated.
Old February 7th, 2018, 07:01 PM   #2
rupej
United States
rupej is offline
Does it need to be NEMA rated for UL or code reasons, or are you just trying to make sure that no water enters the enclosure?
If the latter, going through the bottom of the enclosure is pretty foolproof.
Old February 7th, 2018, 07:09 PM   #3
jraef
United States
jraef is offline
jraef's Avatar
Do a search for the term "CGB connector", it's an old designation for a cord connector with a rubber compression seal originally made by Crouse Hinds (who is now part of Cooper / Bussman, who is not part of Eaton...) Over the years, CGB became a common industry term and a search for it will link you to pretty much all of the major suppliers now.
The difference between this and a Roxtec seal is that with Roxtec, you can get one seal for multiple cables / tubes etc., with CGBs it's one connector for one cable/tube (for the most part). Roxtec seals are also fire stops and rated for marine bulkheads (meaning pressure tight), that's why they are so much more expensive. But if you don't need all of that, they are often budget busters.
Old February 7th, 2018, 07:19 PM   #4
geofftheelectrician
Canada
geofftheelectrician is offline
geofftheelectrician's Avatar
If jraef’s solution is something you would use, a current part number is a Thomas & Betts 2522 which has a 1/2” NPT thread and the rubber grommet with approx a 3/8” opening. If NEMA 4 is required, you can use a sealing ring T&B part 5302.
Old February 7th, 2018, 08:54 PM   #5
Cow
United States
Cow is offline
I'd recommend a cord grip bushing like Jraef mentioned. You can add a sealing washer too if you need it.
Old February 9th, 2018, 03:58 PM   #6
Zlinger
United States
Zlinger is offline
Thank you all for the great responses.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Nema 7 Classification Help RRoc LIVE PLC Questions And Answers 7 January 29th, 2017 05:44 PM
Nema 1 = IEC? NetNathan LIVE PLC Questions And Answers 2 August 4th, 2016 12:46 PM
8 Pin Mini Din connector on Allen Bradley-RS-485 comms Scott Hill LIVE PLC Questions And Answers 18 March 31st, 2015 06:34 AM
AB DH+ connector gautham LIVE PLC Questions And Answers 9 February 14th, 2014 05:43 PM
TI 500 Series Connector Problems nighthawkjw LIVE PLC Questions And Answers 4 October 11th, 2006 08:11 AM
