plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 9th, 2018, 01:30 PM   #1
rupej
United States
rupej is offline
Keyence SR-1000 on a MicroLogix vs CompactLogix?
I have a customer that wants to install a barcode scanner to read labels coming out of a label machine just before they are put on bottles going down a conveyor.
The idea is to have the operator enter the expected UPC code on an HMI, and if the SR-1000 sees any label that does not have that same code, to shut down the line. This would prevent the wrong label being put on the bottle.
The labeling machine has a MicroLogix 1400, but I'm wondering if there are are any add-on instructions available for Studio 5000 that would make this much easier? Does anyone have any experience with that? It would be pretty easy to stick in a new 5380 CompactLogix if it so. The Keyence site to download manuals and sample code is down right now.
Also, if it's possible, I'd like to set the barcode scanner to automatically scan as fast as possible at all times to increase the chance of catching each label- is that something that works or do I need to figure out a way to trigger it with every label coming by?
Thanks in advance- this will be my first time playing with packaging equipment.
Old February 9th, 2018, 01:58 PM   #2
jstolaruk
United States
jstolaruk is offline
I routinely interface SR-1000 to Compactlogix (4 as we speak). Very easy to interface, you'll need their Auto ID Network Navigator to set your device up but its very straight forward. No AOI but you could roll your own. You can set it up to read multiples very quickly.
I haven't used it with a ML1400 or if I have its been a very long time and I don't recall any difficulty.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old February 9th, 2018, 03:14 PM   #3
janner_10
Supporting Member
United Kingdom
janner_10 is offline
Quote:
Originally Posted by rupej View Post
The idea is to have the operator enter the expected UPC code on an HMI, and if the SR-1000 sees any label that does not have that same code, to shut down the line:
Sounds dramatic! Could you not just eject it into a scrap bin?
Old February 9th, 2018, 03:36 PM   #4
Dravik
United States
Dravik is offline
Quote:
We shut down on a wrong code as well.(Pharma)
Might be a similar process where if the barcode is wrong something has gone horribly wrong somewhere and product quality could be impacted.
Old February 9th, 2018, 05:09 PM   #5
BlueAltezza
United States
BlueAltezza is offline
Keyence scanners are CompactLogix do play nicely and set up in no time.
Setting it up on a Micrologix is a little more cumbersome due to the messaging structure, but still works.
In my experience with most scanners we install a button on the screen or a push button to train the scanner on the correct code. I've found that to be more reliable than having operators manually punch in all of the numbers from a barcode on a hmi. This also eliminates the additional messaging needed and allows you to keep the interface between a Micro and SR to just discrete i/o.
Or just get really wild and add a hand held scanner to send info to the SR! I've had more customer requests for that over the past year or two.
Old February 9th, 2018, 06:31 PM   #6
rupej
United States
rupej is offline
Quote:
Oh wow, I didn't realize that was possible. In that mode, could the SR scan continuously, as fast as possible, and keep an output held as long as the last scan was a good code, and then turn the output off when it wasn't? That would eliminate a lot of screwing around with the code!
Old February 12th, 2018, 08:22 AM   #7
BlueAltezza
United States
The SR1000 is pretty fast, so the best thing to do is make sure it's tuned and people aren't moving it all day. If you're reading the label when it's stopped, you can resize the field of view which will speed things up as well.
If it's moving, you'll want to set it up in a burst or continuous mode to help find the code. I do believe there are settings to help with moving targets in the AutoID navigator so be sure to look into that.
As for keeping the output high - someone could just jump the pass input on the plc and force everything to pass. My preference is assuming every label is bad until a signal from my inspection device tells me it is good, and that signal must go high during my inspection window.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PanelView C300 and MicroLogix 1000 Beenlacoshda LIVE PLC Questions And Answers 0 August 4th, 2015 10:28 AM
Replacing a MicroLogix 1500 with a CompactLogix L43 asterof LIVE PLC Questions And Answers 8 May 7th, 2009 07:02 PM
Telemec HMI (XBTGT2120) with micrologix 1000 plc. Anyone done it? timbo_uk LIVE PLC Questions And Answers 6 September 3rd, 2007 02:58 AM
Micrologix 1000 replace relay with transistor e27978 LIVE PLC Questions And Answers 20 August 16th, 2007 08:04 AM
Micrologix 1000 John Grizia LIVE PLC Questions And Answers 3 November 19th, 2002 08:33 PM
