plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 13th, 2018, 03:17 PM   #1
aand74
Belgium
aand74 is offline
Modified sine curve motion
I already succeeded in programming a function to find parameters of fifth order polynomial, in the runtime of a motion controller.
To use if at runtime the cam has to be calculated.
Next to polynomials there also exist sine curves for cam profiles.
More in specific, when should I use the modified sine curve?
When does it have an advantage to a polynomial?
I suppose a modified sine curve is a sine curve where the first and last part are not a pure sine, but the middle part is.
If I should write a function to be executed at runtime in the controller, to calculate a modified sine curve, based on start and end position and velocity,
how should I start? What function should be used in the first and last part?
For the sine part, how to calculate amplitude, phase and period?
Old February 13th, 2018, 06:02 PM   #2
Peter Nachtwey
United States
Peter Nachtwey is offline
Peter Nachtwey's Avatar
When you say sine curve do you mean s-curve?
s-curves start and end a ramp with the acceleration at 0.
This can be done with half a sine wave but it is not clear what you are trying to do.
A sine is generated using a polynomial. Usually the order is very high.
A fifth order polynomial will execute faster than a sine function. The motion profiles are similar. The peak acceleration using a sine function is 1.57 or PI/2 times the average acceleration. The peak acceleration using a 5th order polynomial is 1.5 times the average acceleration. You can see there isn't much difference.
I do not know what you mean by modified sine curve.
To do what you want to do requires calculus. The motion controller should have these functions built into firmware. You should not need to write them.
__________________
"Living is easy with eyes closed, misunderstanding all you see...." Strawberry Fields Forever, John Lennon
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Motion : quadratic parabolic speed curve aand74 LIVE PLC Questions And Answers 9 October 17th, 2016 11:34 PM
Editing Mutiple Motion Tasks in a Kollmorgen AKD over Modbus TCP/IP Eric Nelson LIVE PLC Questions And Answers 0 March 19th, 2015 09:55 PM
CANopen motion controller wim_ LIVE PLC Questions And Answers 8 October 20th, 2010 02:24 PM
Blended Motion. What Controller? Orn Jonsson LIVE PLC Questions And Answers 13 January 16th, 2008 09:59 AM
Hydraulic Control Advances Jasonc24 LIVE PLC Questions And Answers 14 June 16th, 2005 02:52 AM
