plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 14th, 2018, 09:18 AM   #1
technolog
United States
technolog is offline
1746-HSRV SLC servo module homing routine problem
I have a machine I'm trying to refurbish. Currently, it won't home without intervention. It's using a 1746-L532 processor with two 1746-HSRV SLC servo modules controlling two Moog hydraulic servo valves via a Moog amplifier.
When I press home, both axes move in a negative direction to their respective home limits. Both axes are configured to home to a limit switch (M0:s.0/10=1, M0:s.0/9=0) without the use of marker pulses. I believe they're meant to reverse to the limit switch (which are positioned at the negative end of travel) then forward off it and stop with that position being home. At least, that's what happens when I intervene.
I've checked that the configuration has been downloaded successfully before attempting to home and that the axes aren't in an e-stop state.
To get the axes to home, I have to change the sign of the "Speed Direction to Start Homing Axis" block command parameter (O:s.8 & O:s.9 - two words COPYed from F33:1 float). It is set to -0.2 (the "% Acceleration Ramp", O:s.6 & O:s.7, are set to 0.0) and I change it to 0.2. Now, when I try to home, the axes go forward, away from the home limits to their mechanical limits. Next, I change the speed/direction parameter back to -0.2 and this time, when I press home, the axes both move in a negative direction until they make their home limits then change direction until they're just clear of their limits and stop with both axes successfully homed.
Does anyone have any ideas what might be happening?
I'm not sure if it's related but what is the purpose, in the example rungs in the module manual (1746-um613_-en-p.pdf) of the FLL instruction in the Home Axis example? It fills N31:0 through N31:5 with 0s. It looks like it's to make sure that no other motion is happening. This program doesn't do that.
Any help would be greatly appreciated. When it IS homed, the auto cycles are working great, so hopefully I can get this over the finish line soon.
I've attached the .rss program file.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
problem with siemens profisafe safety module dotolee LIVE PLC Questions And Answers 12 March 29th, 2012 02:16 PM
Problem with 1756-IF16 AI Module shamyl LIVE PLC Questions And Answers 3 August 13th, 2010 02:43 AM
AB 1746-HS module - IMC 110 motion controller raj LIVE PLC Questions And Answers 12 February 20th, 2009 01:36 AM
SLC processor faults when inserting a module in Run mode ... Ron Beaufort LIVE PLC Questions And Answers 12 September 13th, 2004 10:39 AM
SLC 5/05 and BAST Module Popefester LIVE PLC Questions And Answers 7 February 10th, 2004 03:11 AM
