plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 14th, 2018, 09:35 PM   #1
makr8100
United States
makr8100 is offline
Sensor Selection
I am looking for a sensor that is PNP 24V that can sense distance up to 2m, and have had the best luck with lasers. We only need a digital out so instead of dropping a thousand on Keyence LR-T sensors each time production breaks them does anyone know of a sensor with configurable distance and digital out? Unfortunately we need to read white on white, so that rules out the standard photo eyes. We've attempted beams and reflectors but of course with 2 parts to each of those options they break twice as often.
Old February 14th, 2018, 10:08 PM   #2
Geoff White
Australia
Geoff White is offline
You might have better luck if you describe the situation better. Ultrasonic or Time of Flight sensors are good for single ended operations.
Old February 14th, 2018, 10:09 PM   #3
seth350
United States
seth350 is offline
seth350's Avatar
Ultrasonic Sensor?
https://m.balluff.com/local/us/produ...%5D%3DPV123383
Have not used their ultra sonic sensors but they make a fine laser distance sensor.
__________________
“Did the Lord say that machines outta take the place of livin’, and what’s the substitute for bread and beans? Do engines get rewarded for their steam?” -John Henry
Old February 14th, 2018, 10:22 PM   #4
makr8100
United States
makr8100 is offline
We're trying to count pizza crusts go by on a conveyor. Near white crusts on a white conveyor with a bleach white UHMW track on the opposite edge. We've successfully used reflector-type sensors but the reflectors keep getting ripped out by production and/or sanitation.
We considered Keyence LV-N (have had success with them in other areas) but QA didn't like the idea of multiple wires in that location. We went with an LR-TB5000 (could have settled for a LR-TB2000 and saved a few bucks) which worked great for about a month until it too was damaged. Someone removed it (why? no clue...) and broke a pin off.
The powers that be like the LR-T but apparently don't want to be dropping $1000+ every time we have to replace one.
Old February 14th, 2018, 10:48 PM   #5
PapaSmiff
United States
PapaSmiff is offline
You might want to look at Banner U-GAGE T30 series ultrasonic sensors. We've used them for tank level - decent and, I think, relatively cheap. Their one problem for us is they are not well sealed against washdown but we still use them here and there.
Old February 14th, 2018, 10:55 PM   #6
seth350
United States
seth350 is offline
seth350's Avatar
Aaaah, the dear sanitation crew.
Keyence:
https://www.keyence.com/products/sen...lr-z/index.jsp
Color or transparency doesn’t affect it. But probably not available in 2 meter range.
Also can purchase a stainless steel mount that will encase the entire sensor.
We use them on cranes in an anodizing line.
__________________
Old February 14th, 2018, 11:02 PM   #7
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Sometimes the mounting is more important than the choice of sensor...especially when hose monkeys...er I mean sanitation associates are involved.
Maybe you can recess a reflector in the UHMW side rail. And build a heavy duty stainless steel guard around the sensor.
What sort of response time is going to be required?
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old February 15th, 2018, 08:06 AM   #8
BlueAltezza
United States
BlueAltezza is offline
Banner Q4 series might help - you'll have to check the available models for distances. They can do a distance/contrast blend for detection and way more affordable compared to the Keyence equivalents.
Old February 15th, 2018, 08:30 AM   #9
Christoff84
Canada
Christoff84 is offline
Christoff84's Avatar
Have you looked at IFM, cheaper then keyence, 5 year warranty and IP67 rated, can configure outputs based on distance the sensor sees.
https://www.ifm.com/products/us/ds/O1D100.htm
Old February 15th, 2018, 10:44 PM   #10
makr8100
United States
makr8100 is offline
Thanks for the input everyone, probably going with ultrasonic. There's a Sick that looks pretty affordable.
https://www.sick.com/us/en/distance-...1102/p/p334364
Old February 16th, 2018, 08:16 AM   #11
kolyur
United States
kolyur is offline
kolyur's Avatar
+1 for the Banner Q4X. We've used a bunch of these and they work well. I like the SS housing. We had one DOA out of the box, distributor replaced it, otherwise no problems with reliability. The built-in display is nice for configuration. They're in the $200-ish range I think.
https://www.bannerengineering.com/us...eries.html#all
__________________
John
Old February 16th, 2018, 01:14 PM   #12
alive15
United States
alive15 is offline
Buy a used instead of brand new Keyence LR-tb2000c sensors for cheaper price, those work great and last a long while. Super-low maintenance and easy to program. You could probably buy one off e-bay for $300-400.
Automation direct has one for $350 that checks up to 10m called the OPT2014, check them out also.
Old February 16th, 2018, 01:28 PM   #13
Gomez_
United States
Gomez_ is offline
+1 for IFM, but I wouldn't use the O1D100, it's more expensive because it supports analog out. Id probably go with something like this:
https://www.ifm.com/ifmus/web/oidl3.htm
Old February 16th, 2018, 01:31 PM   #14
dcam
United States
dcam is offline
ifm effector has sensors that will do what you need and are decently priced, depending on the nature of the surface you are hitting ,laser would prob be best. dig out or 4-20. configurable
Old February 16th, 2018, 06:18 PM   #15
Dirt
Sweden
Dirt is offline
Get a webcam and point it at the location of your nice and shiny Keyence.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
