plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 19th, 2018, 04:24 PM   #1
Bob C
United States
Bob C is offline
Question RSLOGIX 500 EVMOVEW lost all Activations.
Hi All,
I upgraded RSLogix 500 5.xx to 9.05. I have a general SanDisk jump drive that had several AB activations on it. I have used EVMOVE on this jump drive without any issues from time to time(I don't have a lot of AB controllers). When I went to move the RSLogix 500 activation to use 9.05, I got an error message "Error reading activation file" and all the activations that were there are gone. I see a lot of talk out there regarding the EVRSI.sys file attributes and unfortunately it is no where to be found on the jump drive or PC I was attempting to make the move to. All hidden folders and files are accessible BTW. Any thoughts on what may have happened, or where these activations may live now? Thanks.
Old February 19th, 2018, 04:29 PM   #2
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
My advice is to contact Rockwell with your serial numbers and get them converted to Factory Talk activations.
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old February 19th, 2018, 04:42 PM   #3
James Mcquade
United States
James Mcquade is online now
Welcome to the forum.
version 9.05 does not support the old EVERIS style of activation, it uses Factory Talk activation.
As already posted, contact Rockwell.
james
Old February 19th, 2018, 04:50 PM   #4
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Another thing with EVRSI activations:
If you try to move them using Windows 10: EVMove and EVMoveCF will go through the motions, but not create the activation on the new drive - AFTER it has removed them from the old drive - permanently deleting them and then going through Rockwell Tech Supp IF you still have the master key floppy disk, otherwise they are lost for good.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old February 19th, 2018, 04:58 PM   #5
Bob C
United States
Bob C is offline
Thank you to all that have replied. Maybe someone will see the reply from Aabeck before attempting the same process with yes... Windows 10. I was able to recover the 500 activation through FTA, but the others are more complicated. Thanks again.
Old February 19th, 2018, 07:18 PM   #6
JaxGTO
United States
JaxGTO is offline
I have seen that error when trying to remove an activation and something RSx is running like RSLinx. Basically its really getting a file sharing violation but its not smart enough to tell you that.
Old February 19th, 2018, 08:09 PM   #7
CaspianSage
United States
CaspianSage is offline
CaspianSage's Avatar
WIN 10 does corrupt the file if you do that but even with older versions to move a key to a USB stick you need to use a different program, Unless they have changed things ....
You need EvMoveCF.exe to move to a USB drive. I don't know if you can get it anymore from RS so if you need it let me know I will send it to you as long as there is no copyright violation and I don't think there is. ( https://www.rockwellautomation.com/g...tivations.page )
Another Hint.. For your own use.
Get an old copy of GHOST and run it on XP or maybe Win 7 ( Have not tried that.) I used 5.1c and maybe 2003 I don't remember.
I keep a ghosted drive of the one I use with rslogix 5 that has keys on it so If my key gets corrupted all I have to do is put it in as the master. I keep all data and plc programs on a server so I don't loose anything stored on a local pc.
Make a ghost image of your drive with the key. It will copy it and not corrupt it but it may not work with the newest versions of Ghost and it does not work with any other image software I have tried.
Any way you will know when you boot up with the ghosted drive if it worked or you can put it in as a slave and check it and transfer a key from the slave to your original master.
I imaged my hard drive then moved the key on to the original and ended up with two keys, I did this several times until I had 5 or so extra keys and then moved them to other drives and USB sticks just for some insurance..... I think I have about 7 copies of the original key and when running the move program it recognizes all of them.
Of course you cannot share them but you have a ready backup that way.
You can move a key to a file server so long as the Archive bit is not set on the file - no backup is run on the drive with the key or the file is set to be skipped, and the drive must not be mirrored. There is TID somewhere on Rockwell's site about moving to USB sticks and storing keys on file servers.
__________________
Caspian
1+1 = 3 and I never was good at math.
Old February 20th, 2018, 10:18 AM   #8
nehpets
Wales
nehpets is offline
nehpets's Avatar
When moving activations via Evmovecf on windows7 upward you need to run as administrator otherwise the activations are removed from source drive but don't appear on destination drive.
Steve
__________________
Why do programmers get confused between Halloween and Christmas - OCT31 = DEC25
Old February 20th, 2018, 12:59 PM   #9
PLC Pie Guy
Canada
PLC Pie Guy is offline
PLC Pie Guy's Avatar
Quote:
This works with Acronis. Using Acronis, in combination with VMware Workstation you can do just about anything. Its been a long time since I played around with that stuff though!
Old February 20th, 2018, 05:31 PM   #10
EngDave
United States
EngDave is offline
Thank you nehpets. I always seem to forget trying to run it as an administrator. I was going to chime in and say it's not just Win10 but Win7 as well. But now I'm going to go try running it as an administrator. Thanks.
Old February 20th, 2018, 06:48 PM   #11
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
Running as administrator works in Windows 7 & 8, but in Windows 10 the activations are never created after deleting the files on the old drive even when running as administrator
__________________
http://aabeck.com
Old February 21st, 2018, 08:47 AM   #12
CaspianSage
United States
Good Reminder
Quote:
That is a good reminder - RUN AS when you run it..
I hate dongles and software keys. Just gives hackers another Job.
I get software protection but Rockwell keys are too fragile.
__________________
Caspian
Old February 21st, 2018, 09:06 AM   #13
James Mcquade
United States
in the original post, he is using version 9.05 which does not work with the old everis activation scheme, it uses factory talk.
if I am wrong, someone please point it out.
regards,
james
Old February 21st, 2018, 10:37 AM   #14
Mad_Poet
United States
Mad_Poet is offline
Caspian Sage > Make a ghost image of your drive with the key. It will copy it and not corrupt it but it may not work with the newest versions of Ghost and it does not work with any other image software I have tried.
Dear Sage,
I can confirm that that works with Ghost version 8 and I think 11. Nice trick.
Did you ever try it with AOMEI backupper?
Poet.
Old February 21st, 2018, 12:07 PM   #15
CaspianSage
United States
Quote:
Originally Posted by Mad_Poet View Post
Caspian Sage >
Poet.
No Just Ghost, Drive Image and one other but I don't remember the other one.
__________________
Caspian
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
RSLogix 500 & SLC 500 bga6418 LIVE PLC Questions And Answers 10 March 30th, 2016 08:21 AM
Differences in RSLogix 500 packages? wildcatherder LIVE PLC Questions And Answers 9 October 7th, 2009 10:55 AM
Lost RSLogix 500 Program Password gocanna LIVE PLC Questions And Answers 3 August 3rd, 2009 04:04 PM
RSLogix 500 7.30.10 not showing comments online IPSI John LIVE PLC Questions And Answers 1 May 13th, 2009 11:57 AM
RSLogix 500 bug bit me today.... jstolaruk LIVE PLC Questions And Answers 1 February 3rd, 2006 01:08 AM
