1.6 to 2.8 VDC actuator feedback problems
Gyrus
Feb 2018
Dammam
Hi All..
I have a fuel controller that only accepts 1.6 to 2.8 VDC feedback from the actuator. I need to replace that with a 4-20 mA or a 0-5 VDC feedback actuator.
Any Ideas on how I can accomplish this??
The fuel controller will not accept changes to its configuration.
I have been requested to test this proportioning valve for PLC control of flow/pressure. Dwyer Series SVP Proportioning Solenoid Valve The flow...
417
We normally ground the -24VDC side of a control systems power supply. What are you folks thoughts about grounding the -24VDC side of a class 2...
107
I have a conundrum with this current circuit. I have a Siemens 1215C AC/DC/Relay and an old drive - Ratiotrol (now Boston Gear company I...
1,169
I have begun using 480VAC power supplies in my panels to keep heat from a transformer out of the panel. This works great if the panel is mounted...
17
4,134
Good Afternoon , It seems like we always have problems with using Type J Thermocouples with our slip rings . Would using a RTD at 10...
1,639
