Red lion 306A and file viewer.
fannar
Oct 2017
iceland
Good day
I'm having a problem using the file viewer with red lion i have compact flash card from silicon power 32GB (read up to 60mb/s)
I started by creating directory and file
Createdirectory("/LOGS");
CreateFile("/LOGS/test.txt");
Both return 1
then when i open the file viewer it says no files in directory
I have tried having both root directory empty as well as /LOGS and LOGS
it doesn't work :(
Do you guys have any ideas ?
Regards
Fannar
Probably a daft question. In the properties of the File Viewer did you set it to look for TXT files? As standard it is only set for CSV.
Trying to get a G306A panel to talk to an SDM120CTM meter but i can't make the Red Lion make sense of the response from the meter. Using PC...
837
Looking for some help on the red lion side I was able to diver out all the port settings to get the hmi to talk to elc having the are-485 light to...
1,100
Hi guys Red lions website have been down for some days now so i can't find any info. I'm trying to make a cable to connect a barcode scanner to...
1,580
Just getting into learning the Crimson 3.0 database software and I need some help. I am trying to figure out the reason why the G306A will not...
4,301
Good Day Everyone! We have a project the requires an encoder connected to a Paxi Meter and then into the HMI in order to display/record depth and...
3,153
