plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 26th, 2018, 06:31 AM   #1
jatkinson924
United States
jatkinson924 is offline
SLC 50/3 Connecting to Local Network
Does anyone have an suggestions on connecting a few SLC 5/03s to a local network? I've got a few Ethernet switches mounted in our ceiling for other PLCs we are using and would like to make the connections there.
Old February 26th, 2018, 06:38 AM   #2
Aabeck
United States
Aabeck is offline
Aabeck's Avatar
The Rockwell way is to use a 1761-NET-ENI that connects the 5/03 serial port to the network. You can find them on Ebay for S250 - $400, but make sure they have an Ethernet port, as some listings for NET-DNI's call them NET-ENI's but are DH+ not Ethernet
I am sure there are other aftermarket devices others on the forum will know of.
__________________
Never underestimate the quality of idiots that will be running your machines
http://aabeck.com
Old February 26th, 2018, 06:40 AM   #3
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Are the 5/03's connected to a network (DH485) or are they just standalones PLC's
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Old February 26th, 2018, 06:40 AM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Are the serial ports on the 5/03s in use? If not, look into the Digi One IAP serial to ethernet bridge module.
https://www.digi.com/products/serial...gioneiapfamily
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old February 26th, 2018, 06:41 AM   #5
geniusintraining
United States
Quote:
The DNI is devicenet not DH+
__________________
Old February 26th, 2018, 06:54 AM   #6
jatkinson924
United States
Quote:
They are standalones. I was thinking of doing a DH485 Network and then buying a RS485 converter to Ethernet. Would I need the 1747-AIC to have a DH485 network?
Old February 26th, 2018, 07:00 AM   #7
geniusintraining
United States
You could do a network but I think I would do Paul's suggestion with the Digi. If you had a 485 network inplace then I would look at just bridging the network to a Ethernet network
Are the RS232 (DB9) open on the 5/03?
__________________
Old February 26th, 2018, 07:15 AM   #8
padees
United States
padees is offline
padees's Avatar
Prosoft has a new module to replace the NET-ENI.
https://www.prosoft-technology.com/L...ni-Replacement
Not sure what it cost tho.
Old February 26th, 2018, 07:19 AM   #9
jatkinson924
United States
No the HMI is connected thru the RS232 port. Would I need a Digi for each PLC? or daisy chain a DH485 network and have the Digi at the last PLC? The PLCs are around 60 ft of each other?
Old February 26th, 2018, 07:32 AM   #10
geniusintraining
United States
Quote:
You have a few options but none are great.... do you have a budget? you may want to think about changing them to 5/05's
__________________
Old February 26th, 2018, 07:49 AM   #11
jatkinson924
United States
yeah the budget is the problem. I've also got 4 MicroLogix 1500s I need to connect to the network as while. Channel 1 is able on them.
Old February 26th, 2018, 07:57 AM   #12
geniusintraining
United States
Well at least their not asking a lot
I still think it maybe cheaper to buy some used 5/05's and changing out the CPU's
Are the 1500's a LSP or LRP processors
__________________
Old February 26th, 2018, 08:40 AM   #13
jatkinson924
United States
well at least their not asking a lot
i still think it maybe cheaper to buy some used 5/05's and changing out the cpu's
are the 1500's a lsp or lrp processors
lrp
Old February 26th, 2018, 09:02 AM   #14
geniusintraining
United States
So on the 1500's you can change them for 1400's or use a 1761-NET-ENI or padees Prosoft (not sure of cost either) or OkiePC's Digi (525.00)
The LSP only has one port but your LRP has two so you can add the device to your unused port
__________________
Old February 26th, 2018, 09:31 AM   #15
jatkinson924
United States
What about this for the SLC5/03?
http://www.prosoft-technology.com/Pr...Module-for-SLC
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Subnet question... WillM LIVE PLC Questions And Answers 15 April 1st, 2016 02:08 AM
Connecting Magelis XBTGT6330 t0 Modbus plus Network RZR LIVE PLC Questions And Answers 0 August 23rd, 2012 08:15 AM
AB DH485, SLC 5/04, AIC+ Comm Failure gnieport LIVE PLC Questions And Answers 2 August 31st, 2011 03:08 PM
FactoryTalkViewStudio 5.1 Local to Network conversion shrirampendse LIVE PLC Questions And Answers 2 July 6th, 2010 09:05 PM
slc 5/04 DH 485 network problem MarkM LIVE PLC Questions And Answers 0 September 4th, 2003 06:51 PM
