Safety Switch Nomenclature
milmat1
Aug 2005
North Carolina
209
Folks,
On a machine, I have some safety bumper switches placed so an operator can bump them with his arm and it forces an ESTOP condition.
I need to label these safety switches (on the machine), but not sure what to call them. I can't call them an ESTOP.
How about some ideas here....
Safety Stop..
Shut Down Switch..
SAFE STOP
...Etc
What are the limitations as for what they are labeled.. If any ??
Not sure you can use a safety edge as an “E-stop”. Most of the ones I’ve seen are self resetting when pressure is removed and most standards require manual release of an E-stop. I believe safety edges are intended for guarding hazards (pinch points) similar to a light curtain or area scanner.
The semi-official industry term for them is a "Safety Edge" device, so I have used signs that say "Safety Edge - Emergency Stop"
This is about what I had decided to do, Thanks...
That is what they are doing. guarding an area where the operator is very close to a hazard. However if tripped they will kill my main safety relay, requiring a push button manual reset of the machine..
I wouldn't call it an E-stop. Some standards require E-stop to be "mechanically lathing" [ISO 13850 4.4.3], or self-latching [NFPA 79 10.7.2.2]. Can you use a pull wire E-Stop instead?
Folks, Do you know of a safety rated key switch ? Not the big key disconnect switches, but a switch that will simply provide an input to my safety...
22
3,909
Good Afternoon , I'm thinking of using Allen-Bradley 440G-T27240 Locking Switch, 24V AC/DC, Solenoid. Can you use the MSR-127TP with this ...
1,075
Good Afternoon , I putting a Rockwell Automation Safety System. I was wondreing if a TLS-Z GD2 Guard Locking Switch would work well with a...
1,587
Hello, I'm looking to install a separate lockable cam switch in conjunction with the AB 440r-S13R2 relay to be used as part of the Estop Zone to...
3,084
So given this Omron D4NS-9BF. The Manufacturer calls this a DPST-NC. The contacts are closed when the door is closed. But to me it seems like this...
44
13,058
