plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 1st, 2018, 04:02 AM   #1
Allen123
China
Allen123 is offline
Allen123's Avatar
Wink How do you make panel door cutouts?
As I was doing an HMI cutout yesterday, kicking up profuse grit and spark with my die grinder and seeming to take forever, it dawned on me that perhaps there's a better way. So what better place to ask.. how do YOU make your cutouts?
__________________
Industrial Panel PC Manufacture at http://www.szjawest.cn/
Old March 1st, 2018, 04:17 AM   #2
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Design in CAD and send to water-jet cutter. Mostly stainless work. Then get 1.5mm thick stainless cut for overlay and get acid etched for label buttons - lasts a lifetime - even in CIP acid wash down environments.
__________________
Regards,
Patrick
https://www.youtube.com/user/MrMatrixEngineering
Old March 1st, 2018, 04:22 AM   #3
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
free image hosting websites
__________________
Regards,
Patrick
Old March 1st, 2018, 04:24 AM   #4
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
Use the 4 holes on the right and left of button cluster to hold the text plate on (and as spares for future expansion), oversize the holes round the push button so it pops on over them.
For large amount of button clusters (not common these days due to HMIs), get a plate on the back that has the button ID etched - correlates to schematic.
Before I had CAD I just sent the dimensions to the water-jet shop and let them transfer them.
__________________
Regards,
Patrick
Old March 1st, 2018, 04:32 AM   #5
lfe
France
lfe is offline
Using this electric tool but putting before a Masking Tape ( painter's tape) around the hole. Always wear protective glasses !
__________________
Suppanel HMI
Old March 1st, 2018, 04:51 AM   #6
brusarp
Italy
brusarp is offline
We use this...
http://www.cembre.it/product/details/42616
https://www.youtube.com/watch?v=MW9fcfryg2w
Old March 1st, 2018, 06:00 AM   #7
jraef
United States
jraef is offline
jraef's Avatar
Plasma cutter. If you have multiples of the same hole size or repeated projects, make a plywood or scrap metal template of the cutout with the proper margins for the tip radius. Place the template where you want the hole and just run the plasma cutter tip around the perimeter. If you’ve never used one, you will never go back to saws or abrasion cutters. Rent one first to try it.
Old March 1st, 2018, 06:20 AM   #8
John Morris
United States
John Morris is offline
John Morris's Avatar
+1 to lfe
But use lots of tape, the fall off will get under the pads and scratch the surface
The right blades make all the difference.
Mark bold lines, cut to the inside, take your time.
Some of us do not have the luxury of a water jet........
__________________
"When nothing is going right, go left."
"Even a fish wouldn't get into trouble if it kept its mouth shut."
(I should probably look into this)
Old March 1st, 2018, 06:55 AM   #9
Archie
United States
Archie is offline
For larger cutouts a metal cutting circular saw gives the fastest, cleanest, and straightest cuts. Most of the time the cut edge does not need deburred. Does not burn the paint and no sparks, just flying chips. It cuts through panel doors like using a wood circular saw to cut 1/4" plywood.
It also works great for cutting things like conduit or steel stock in the field.
https://www.milwaukeetool.com/Produc...r-Saws/0740-20
BUT... It takes a little practice and it can be dangerous if not used with care.
__________________
Expectations lead to disappointment. Appreciation leads to satisfaction.
AdvancedHMI - HMI Software without the license key hassles
Old March 1st, 2018, 07:31 AM   #10
Doug-P
United States
Doug-P is offline
Doug-P's Avatar
Quote:
Originally Posted by jraef View Post
plasma cutter.
+1
__________________
Let's eat Grandma!
Let's eat, Grandma!
Words are very important, but punctuation saves lives...
Old March 1st, 2018, 08:17 AM   #11
BlueAltezza
United States
BlueAltezza is offline
Quote:
Originally Posted by John Morris View Post
+1 to lfe
+1 again!
My shop guys do this method often and it's been the easiest for them.
So true about the blades, by far the most important part.
Old March 1st, 2018, 08:21 AM   #12
lfe
France
lfe is offline
Quote:
Originally Posted by BlueAltezza View Post
+1 again!
Yes, a blade with small teeth and no pendulum action.
__________________
Suppanel HMI
Old March 1st, 2018, 08:30 AM   #13
boardmaker
United States
boardmaker is offline
Could you jigsaw guys make a blade recommendation? I've used it before, but now I'm wondering if I used the wrong blade.
Old March 1st, 2018, 08:49 AM   #14
keithkyll
United States
keithkyll is offline
Quote:
Originally Posted by the_msp View Post
.. send to water-jet cutter. ..
+1. Draw location on panel with Sharpie. Give machinist the cutout info sheets that come with HMI, handle, etc.
Make sure Sharpie marks are on the discard area, or draw on paper. Sharpie can soak in to paint and be tough to clean.
Be aware that panel will get wet in cutting process.
Old March 1st, 2018, 10:29 AM   #15
John Morris
United States
https://www.zoro.com/bosch-jig-saw-b...a3/i/G3579935/
Best ever IMHO
Minimum, a good bi-metal blade.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help Laying out VFD's in a Panel GTUnit LIVE PLC Questions And Answers 5 December 4th, 2016 06:59 PM
FM200 panel vs fire alarm panel Charbel LIVE PLC Questions And Answers 2 April 26th, 2016 01:13 PM
Problems with Uploading a Panel View 550 connected to a SLC 5/03 Shevy LIVE PLC Questions And Answers 8 November 4th, 2013 03:50 PM
Siemens 315-2 PN/DP - Beijer Mobile Panel orense LIVE PLC Questions And Answers 24 May 22nd, 2012 03:40 PM
Panel Construction Question - re: multiple disconnects TConnolly LIVE PLC Questions And Answers 11 October 27th, 2005 03:36 PM
