PLC/Flowmeter Communication Solution !!
richleva
Sep 2012
ontario
79
Hello,
I have a flowmeter in a underground mine with hart data, i need to read it from a micrologix 1400 that is located in surface...I would need a solution that will let the PLC read the information via the mines TCP network ...
I was planning to use modbud TCP IP, but apparently the micrologix 1400 wont work with that ??
Can someone advice..
Thank you
Does the flowmeter supply the data using Hart protocol or Modbus TCP? The ML1400 Series B should handle Modbus TCP just fine, but for Hart, you will need a 3rd party protocol converter.
If you have a ML1400 series A, Modbus TCP is not supported.
Hello,
Thanks you and yes its a Series B
E+H Promag P500 5069 Compact Logix implicit Ethernet IP using endress device description 30ish flowmeters, every time I download, some (but not...
1,255
This particular problem is doing my head in... In our system we have a minisonic flowmeter. One of these. It outputs 4-20mA and is an input into...
1,403
Hello, We are a mechanical engineering senior deign team from the University of Houston building an automated beer brewing system known as HERMS...
4,611
We currently use Watermeter controller here with paddleswitch type of flowmeter to keep the tracking of the water quantity we use in our batch...
2,020
I need to know if a high speed input card will be sufficient enough to pickup up the flow in a metering line with a flowmeter and a 24vdc pulsed...
21
5,075
