plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 1st, 2018, 09:59 AM   #1
IdealDan
Malaysia
IdealDan is offline
Scada with gprs
Hi Guys,
I have a Project whereby my client wants to REMOTELY see data coming from their energy meters. They want a situation where any authorized staff can just log on to a platform (may be a website) from anywhere/location and be able to view the data/value from those energy meter. Can GPRS achieve this? How best can I achieve this?
Thanks in advance.
Old March 1st, 2018, 11:15 AM   #2
gclshortt
Canada
gclshortt is offline
gclshortt's Avatar
You have not provided allot of detail on your existing data. Ill assume that it is on an Ethernet network. I would then use this or something similar to see the information remotely.
https://www.automationdirect.com/stride/index
Regards,
__________________
Garry
https://www.accautomation.ca
Connect with us on Facebook: facebook.com/accautomation/
Old March 1st, 2018, 11:38 AM   #3
IdealDan
Malaysia
IdealDan is offline
Regards,
Sorry Dear, it is not on Ethernet rather it's OPC server communication protocol. then with fibre optics wiring.
The energy meters does NOT has Modbus capability.
Any ideas?
Old March 1st, 2018, 11:46 AM   #4
widelto
Colombia
widelto is offline
widelto's Avatar
I used this several years ago, normally power meter use Mbus.
http://www.techbase.eu/en/products/i...ry-module.html
__________________
My two cents.
Old March 1st, 2018, 11:52 AM   #5
lfe
France
lfe is offline
where are those energy meters located ?
I think that the old GPRS only offers a few services like email, www access, data transfer but I don't know if it's possible to establish TCP connections , mandatory to communicate with an OPC server.
__________________
Suppanel HMI
Old March 1st, 2018, 11:56 AM   #6
IdealDan
Malaysia
IdealDan is offline
If GPRS can give www access (website)and then it is ok! can it?
Second, I hope the OPC Protocol is good for this application?
where are those energy meters located ? AT THE PLANT!
Old March 1st, 2018, 12:11 PM   #7
lfe
France
lfe is offline
No, to have www access in this case doesn't mean to establish other TCP connections.
If they are all in a plant, why not to use Wi-Fi or wired ethernet ?
GPRS is not free, they will have to pay to the telephony provider for each connection point and probably to pay an extra to get static IPs if not the meters will be unreachable ...
It seems possible TCP over GPRS with some hardware https://www.moxa.com/Event/IW/2009/O...odem/index.htm
__________________
Suppanel HMI
Old March 1st, 2018, 12:15 PM   #8
IdealDan
Malaysia
IdealDan is offline
Good friend, they need to see data anywhere an authorized staff is, should be able to log in an view.
Old March 1st, 2018, 02:17 PM   #9
makr8100
United States
makr8100 is offline
Instead of using GPRS use wifi/wired ethernet and have a web server interpret and serve the data. The plant's internet connection can become the address for monitoring. If your devices are OPC already you should have no problem writing an ASP .NET (either C# or VB) site to handle this. Modbus (if available) opens up a lot of possibilities too.
Old March 2nd, 2018, 02:21 AM   #10
IdealDan
Malaysia
IdealDan is offline
Quote:
Unfortunately, the energy meter does not support Modbus.
1. If your devices are OPC already you should have no problem writing an ASP .NET (either C# or VB) site to handle this------IS THERE ADDITIONAL HARDWARE REQUIRED TO ACHIEVE THIS METHOD?
2. Instead of using GPRS use wifi/wired ethernet and have a web server interpret and serve the data. The plant's internet connection can become the address for monitoring.----------COULD YOU PLEASE THROW A BIT MORE LIGHT ON THIS? I will appreciate.
Old March 2nd, 2018, 05:57 PM   #11
makr8100
United States
makr8100 is offline
1. For OPC there should be no additional hardware required, but you'd have to have a server (PC) to communicate with the devices and run the ASP. OPC resources for .NET are here:
http://www.opcconnect.com/dotnet.php
2. The existing LAN should be able to make said ASP server communicate with the devices, as well as the outside world. You would have IT add a DNS entry for the server so it could be accessed. You would then of course want a login system, etc... We're talking about a full blown custom website here just to make sure we're on the same page. I'm not sure your company will look at that as a viable option either, but it's how it would be done properly.
Old March 2nd, 2018, 06:24 PM   #12
the_msp
United Kingdom
the_msp is offline
the_msp's Avatar
I had a request for a black box that could be moved around construction sites and send data of piling tests (load cells).
My proposal was:
a fan-less industrial DIN rail PC
Ignition SCADA
Sierra Wireless 3g/GSM/GPRS
All running off lorry batteries 24V with battery monitoring to the DA PLC (CPX). Was control as well as DA.
Can't report results as it didn't go through - heard through the grape vine that the company had been asking various Integrators to look at this over the last 15 years.
__________________
Regards,
Patrick
https://www.youtube.com/user/MrMatrixEngineering
Old March 3rd, 2018, 07:12 AM   #13
cardosocea
United Kingdom
cardosocea is offline
Quote:
I think they are looking at an Arduino ($$$$) solution...
Old March 6th, 2018, 09:27 AM   #14
lfe
France
lfe is offline
But ... what communication protocols support these energy meters?
__________________
Suppanel HMI
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PLC Recipes and SCADA Brian123 LIVE PLC Questions And Answers 3 November 23rd, 2014 09:18 PM
scada via gprs modem tometrajkov LIVE PLC Questions And Answers 0 November 2nd, 2011 05:36 PM
Net-Eni (MicroLogix 1200) Communication loss over time with Third-Party scada JPS_BPR LIVE PLC Questions And Answers 27 March 23rd, 2011 08:11 AM
Best way to upgrade a SCADA system Johnny T LIVE PLC Questions And Answers 10 May 3rd, 2005 04:38 AM
Preparing a Practical SCADA course ayman metwally LIVE PLC Questions And Answers 11 October 16th, 2004 03:03 PM
