Soap Manufacturing Line Vision PLC Automation
Anup29
Feb 2018
Kolkata
Dear Members,
I have one query in doing PLC program,
Application-
1. Soap Manufacturing Line
2. Soap width 70mm, Speed 180 Soaps/minute, gap between soap min 20mm
3.Omron PLC CP1E series, Omron FH series Vision system
4. We have to check from vision and reject from some rejection system, currently pusher type or air nozzle type,
5. Conveyor speed fixed, the soap comes in this fixed speed conveyor
Doubts:
1. What is best possible camera to rejection system distance we should keep
2. What could be best possible PLC logic Algorithm,
Dear Members , please guide
Regards
Anup
~ 3 soaps per second, so your scan time, camera processing and rejecter reaction time needs to be under this.
Use a shift register, then you can have the rejecter as far down as you want. Consider events such as 5 fails in a row etc when doing calculations.
Depends how you are recording the position of the conveyor, do you have an encoder giving a position or just pulse every xx mm?
In theory, it doesn't matter where the ejection system is as long as you know the position of the soap when you get the rejection signal and the distance to the reject actuator.
The logic is very simple and will be the least of your worries.
My camera scan time is around 200-250ms,
If i go by recording time, it will be good,
Or by encoder feedback, it will be good
I have an MP277 locally and a PC Runtime in the office. Connected thrue Lean CP on a 315 CPU. I've made a batchsystem. I know the PC Runtime...
1,622
Good Morning , I imagine all manufactures are having similar problems. The lack of Maintenance Technicians ( Mechanics ) . Could you share...
22
3,636
GitHub Link: https://github.com/Automation-Standard/Open-Industry-Project This is a little side project I've been working on that I felt would be...
3,408
Good Evening , This sound like a strange idea. This has been on my mind and heart for several years. We have a homeless and drug issue in...
1,861
Hello, I have recently started at a new company and currently in charge of setting up the tolerances for our AOI(s) to judge all of our many...
1,070
