plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 3rd, 2018, 07:07 PM   #1
RheinhardtP
Australia
RheinhardtP is offline
RheinhardtP's Avatar
Office Test Bench/Lab
Hi All,
So we are moving the company to new offices and we have decided to showcase the test bench/ lab area instead of hiding it away in a back room.
So my thinking is to use aluminium profile as the structure of the bench. I think it represents well and is easy to use if you need to alter/adapt change anything.
Portion of the bench will have an acrylic cover to close of power supply section. The rest will have loads of space for din rail to mount controlled, switches or whatever we might be testing at that point.
Below the desk top some drawers to hide the consumables normally used as well as the tools, and maybe some adjustable monitor stands or brackets for touch panels.
Because this will sit in our main office my biggest concern is that it would appear untidy due to cables going all over the place.
Im looking for some ideas around cable management or potentially integrating supply point into the base of the back-plane where the din rails would sit on.
I still want to make it easy to use for the guys when swapping out equipment between projects, and minimize the time it would take to make it look neat and tidy so our client can see the testing processes in action.
Anyone done this before? anything learned that you can share?
Like i said the cable management worries me the most but i am sure with the correct design this can be managed.
Would appreciate whatever advise , or experience you might have had on similar projects.
Oh and any photos with some ideas would be appreciated!!!!
Happy Coding!!!
__________________
“If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?”
― Albert Einstein
www.tier16.com
Old March 3rd, 2018, 08:17 PM   #2
mendonsy
United States
mendonsy is offline
mendonsy's Avatar
Run some plastic wiring duct on the desk to contain the cables. The gray color would probably be less apparent and with a bit of thought you might be able to hide most of it behind the desk.
Old March 3rd, 2018, 10:11 PM   #3
Saffa
New Zealand
Saffa is offline
Some plastic spiral wrap should be easy enough to add afterwards to tidy things up.
My test bench is far from tidy! However what i do have is some old Remote IO mounted on DIN rail and wired to terminals. I have a PLC that is my I/O simulator that drives these. I don't bother with switches etc, all that gets done via the simulator.
Means that the only wiring that needs to change is from terminals to the PLC under test.
For complex stuff i write bespoke simulation code. For simple stuff i have a copy of Intouch and a simple program that drives outputs from buttons and displays inputs as lamps.
Old March 4th, 2018, 05:10 PM   #4
Jeev
Australia
Jeev is offline
Jeev's Avatar
You can run the cables behind the surface you are mounting the components to. That way everything just disappears down a hole at the front, and you can work on whatever you want at the back.
Don't forget a switch that turns the coloured LED illumination when people are walking through
Old March 5th, 2018, 09:28 AM   #5
CapinWinky
United States
CapinWinky is offline
CapinWinky's Avatar
Get some stand-offs to mount you DIN rail a few inches ways from the backing (because you better be including some sort of permanent DIN rail if you have any hope of a tidy test bench) and then use door sweeps mounted on either side of large slots in the backing. All wires come out of components into the slots and disappears into the very easy to access space behind (ideally the DIN rail stuff flips up and self supports, like a hatchback or the other side is cabinet doors).
Also, any wire that is going to be used more than once needs to have ferrules, which means the test bench should own a crimper and array of ferrules. Also fancy terminal blocks and/or plenty of terminal block jumper bars so people aren't trying to cram more than one wire into a terminal point.
__________________
Cycling power is a sign of weakness.
Old March 5th, 2018, 10:23 AM   #6
JohnCalderwood
Scotland
JohnCalderwood is offline
I was given an (almost empty) room to make a test and training facility.
We had the wooden benches already, so they have boxes under the worktop for storing various spare parts, cables, keyboards etc - all labelled.
Above the bench we installed some 3-compartment plastic skirting trunking for the mains sockets and network points for PCs/laptops etc.
Each of the 3 walls was sheeted out above the worktops with some MDF (we make it here..!), these sheets are 6 feet high and about 12 feet wide.
On each of these walls, we have mounted 2 banks of distribution blocks (240V and 24V) alongside an 8-way ethernet hub, all at the top of the board. A power supply cabinet is in one corner of the room, with individual fuses for each of the distribution blocks.
The boards are kitted out with DIN rail, PLCs and slotted trunking, some PLCs are permanent, other spaces for projects.
We have PLC5, SLC, Siemens S7, ControlLogix mounted and used for training purposes, with some temporary switches and lights, as well as a dedicated SCADA system.
I also hope to put in a VSD and motor for training needs.
All done over a couple of years and developing as major projects allow, as we also have a manufacturing plant to run.
Old March 6th, 2018, 08:45 PM   #7
RheinhardtP
Australia
Quote:
I like the idea of the cables being hidden completely behind the panels. Maybe something i will explore, i was also thinking perhaps to have connectors on the back plane . Back entry to the unit will be an issue for day to day power requirements. Im thinking the same with the network points a switch and then network point distributed across the board.
I am not too concerned about additional wiring as switches and other devices can be simulated through SCADA or HMI screens.
Any chance you can share a pic?
__________________
― Albert Einstein
www.tier16.com
Old March 7th, 2018, 03:39 AM   #8
JohnCalderwood
Scotland
RheinhardtP,
attached are a couple of photos of the testroom
Work in progress as usual, other users of the room not as OCD as I am...!
Old March 7th, 2018, 06:33 AM   #9
A_G
United States
A_G is offline
I'm jealous, at every company I ever worked at, any "spare parts" set aside for testing/training were usually "borrowed" and used on customer jobs sooner or later
Old March 7th, 2018, 01:53 PM   #10
RocketTester
United States
RocketTester is offline
I recall that Panduit has (or had) a system where DIN-rail mounts on top of the plastic wiring channel. Personally, I don't like Panduit within an enclosure since the cables become harder to follow, but it does look nice and your setup is out in the open.
In one installation here, they mounted DIN-rail on the front of an aluminum panel and milled long slots alongside it, to feed cables in from the rear. In that case, the rear had DIN-rail T-blocks and was accessible, but yours is flush to the wall.
Old March 12th, 2018, 11:15 PM   #11
RheinhardtP
Australia
RheinhardtP,
Thanks for that John,
Certainly gives me a good perspective of space required on the bench.
Anyone else have some good test bench pics they can share on here?
__________________
― Albert Einstein
www.tier16.com
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1768 - ENBT displays test magicsmoke LIVE PLC Questions And Answers 0 November 18th, 2009 11:41 AM
PLC Test Questions highvoltage8471 LIVE PLC Questions And Answers 2 October 1st, 2009 09:38 AM
OPC test Client cannot connec to RSLinx Proffesional Eric Le Yin LIVE PLC Questions And Answers 0 May 7th, 2009 10:04 PM
Activefactory and Office Compatiblity CHutchinson LIVE PLC Questions And Answers 0 October 4th, 2007 09:35 AM
PID - MicroLogix Temperature Control Peter Nachtwey LIVE PLC Questions And Answers 112 October 11th, 2004 11:18 AM
