plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 4th, 2018, 08:05 AM   #1
Cydog
United States
Cydog is offline
Dog ControlLogix - Timestamping using a CONCAT instruction missing 0 in time
Good Morning ,
I'm working on trying to get timestamping done on some doses. I am very close, thanks to many of you with your advice. I used the two instructions DTOS and CONCAT . Everything is working well except when I see the time , for example 8:06 it appears has 8:6 . What can I do to get the 0 in its right place ? When it turns 8:10 i get 8:10. It only happens when the minutes are single digits .
Thanks so much for your help.
Old March 4th, 2018, 08:43 AM   #2
AustralIan
United Kingdom
AustralIan is offline
Code:
LES    ]-----[CONCAT]
minutes]     [String]
10.    ]     ["0"   ]
             [String]
Put that rung before your CONCAT statement with your minutes String.
Old March 4th, 2018, 04:56 PM   #3
Jeev
Australia
Jeev is offline
Jeev's Avatar
When I'm trying to fill with 0's, I will add 10/100/1000/Whatever to the DINT, DTOS it, and then use MID or DELETE to chop the front off at the relevant spot. For you that looks like adding 100 to your minutes or hours, and then converting and chopping the first letter off.
Old March 5th, 2018, 09:23 AM   #4
cwal61
United States
cwal61 is offline
Check out this thread Post #4
http://www.plctalk.net/qanda/showthread.php?t=11198
It will do what AustralIan explained. Less than 10 CONCAT '0'. I used it for Minutes and Hours.
Old March 5th, 2018, 09:47 AM   #5
RonJohn
United States
RonJohn is offline
RonJohn's Avatar
cwal61, can you double check your link please? Looks like this one's talking about a broken Omron cable
Old March 5th, 2018, 11:00 AM   #6
TheWaterboy
United States
TheWaterboy is offline
TheWaterboy's Avatar
Maybe this will help? add one to length and insert a 0 when less than 9 .
Old March 5th, 2018, 01:42 PM   #7
janner_10
Supporting Member
United Kingdom
janner_10 is offline
Oddly enough, I made a routine exactly for this in the week for a string time stamp for a project.
Quote:
//Reads the PLC date and time and converts it to a string value
//Read PLC Date Time. Write to DateTime in Controller Tags as usual DINT[7] format.
GSV(WallClockTime,,DateTime,PLC_Time[0]);
//Convert Year to String
DTOS(PLC_Time[0],YearString);
//Convert Month to String // Add leading zero if less than 10
If PLC_Time[1] >=10 Then
DTOS (PLC_Time[1],MonthString);
ELSE DTOS (PLC_Time[1],MonthTemp);
CONCAT (strConst[4],MonthTemp,MonthString);
END_IF;
//Convert Day to String // Add leading zero if less than 10
If PLC_Time[2] >=10 Then
DTOS (PLC_Time[2],DayString);
ELSE DTOS (PLC_Time[2],DayTemp);
CONCAT (strConst[4],DayTemp,DayString);
END_IF;
//Convert Hour to String // Add leading zero if less than 10
If PLC_Time[3] >=10 Then
DTOS (PLC_Time[3],HourString);
ELSE DTOS (PLC_Time[3],HourTemp);
CONCAT (strConst[4],HourTemp,HourString);
END_IF;
//Convert Minute to String // Add leading zero if less than 10
If PLC_Time[4] >=10 Then
DTOS (PLC_Time[4],MinuteString);
ELSE DTOS (PLC_Time[4],MinuteTemp);
CONCAT (strConst[4],MinuteTemp,MinuteString);
END_IF;
//Convert Second to String // Add leading zero if less than 10
If PLC_Time[5] >=10 Then
DTOS (PLC_Time[5],SecondString);
ELSE DTOS (PLC_Time[5],SecondTemp);
CONCAT (strConst[4],SecondTemp,SecondString);
END_IF;
//Merged all the strings together
CONCAT(DayString, strConst[1], stTemp[0]); //Add Bracket to Day
CONCAT(stTemp[0], MonthString, stTemp[1]); //Add Month
CONCAT(stTemp[1], strConst[1], stTemp[2]); //Add Bracket
CONCAT(stTemp[2], YearString, stTemp[3]); //Add Year
CONCAT(stTemp[3], strConst[0], stTemp[4]); //Add Space
CONCAT(stTemp[4], HourString, stTemp[5]); //Add Hour
CONCAT(stTemp[5], strConst[2], stTemp[6]); //Add Colon
CONCAT(stTemp[6], MinuteString, stTemp[7]); //Add Minute
CONCAT(stTemp[7], strConst[2], stTemp[8]); //Add Colon
CONCAT(stTemp[8], SecondString, stTemp[9]); //Add Second
//Copy the DateTime string to the Controller Tag
COP(stTemp[9], Date_Time_String, 1);
gives you an idea about the leading zero. If you want the routine, i'm more than happy to send it to you.
Old March 5th, 2018, 05:22 PM   #8
cwal61
United States
cwal61 is offline
http://www.plctalk.net/qanda/showthread.php?t=111989
Looks like I missed the last digit.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Logix5000 - Unconditional Output behaviour when Faulted lambles LIVE PLC Questions And Answers 12 May 16th, 2017 07:43 PM
Time sync PV 1000 to Controllogix clock? elecmech1 LIVE PLC Questions And Answers 1 April 9th, 2013 07:03 PM
ControlLogix - How to clear ONS instruction in Prescan? bobby1234 LIVE PLC Questions And Answers 8 January 10th, 2007 12:04 PM
How AB Timers work. PhilipW LIVE PLC Questions And Answers 0 January 28th, 2005 02:47 PM
Using FSC instruction in Controllogix ettikudiappan LIVE PLC Questions And Answers 2 October 21st, 2002 05:07 PM
