plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 5th, 2018, 02:13 PM   #1
LoganB
United States
LoganB is offline
1769-ECR... are they required??
In normal operation, obviously, we need an ECR for our compact logix to be happy and safe.
In a lab setting, just to do a quick test of an IO card, is there any way to jumper the end of the compact logix block to fool it into thinking there is an ECR in place? I literally have a 20 second test to do and don't want to spend $20 and three days to do it.
TIA!
__________________
Present: Controls Engineer
Future: Skynet Engineer
Old March 5th, 2018, 02:21 PM   #2
LoganB
United States
LoganB is offline
I feel like I can hear Ken shaking his head at me...
__________________
Old March 5th, 2018, 02:39 PM   #3
Geospark
Ireland
Geospark is offline
Geospark's Avatar
Just inhibit the I/O Connection for the module to run the program but do you need to test I/O on this module?
G.
__________________
"A little nonsense now and then is relished by the wisest men".
Old March 5th, 2018, 03:24 PM   #4
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
In general, the 1769 IO bus won't run properly without an end cap, unless the moon is full and your St. Christopher medal is fully charged.
The end cap is not complicated: it consists of just four resistors, but the wiring of them I had to probe with a meter.
R1 = 1000 ohms
R2 = 120 ohms
R3 = 1000 ohms
R4 = 330 ohms
R1 is between pins 2 and Outer Plane (3,5,8,9)
R2 is between pins 2 and 10
R3 is between pins 10 and Inner Plane (1,11,14,16)
R4 is between pins 13 and Inner Plane (1,11,14,16)
If I was just guessing and had only one resistor in my desert island, I would put 120 ohms between pins 2 and 10 because that's a typical CAN termination.
Old March 5th, 2018, 03:47 PM   #5
ASF
Australia
ASF is offline
Saving this one for next time I get stuck in rural China with no end caps and a deadline!
Also, if I'm ever stuck on a desert island with only an Allen-Bradley PLC to signal for help, I want Ken with me.
Old March 5th, 2018, 04:34 PM   #6
Geospark
Ireland
Geospark is offline
Geospark's Avatar
That's great info Ken, thanks.
Now I'm really curious to "see" someone, LoganB?, attempt an ad hoc end cap. Would the CAN termination be enough I wonder? Are the others just window dressing like surge suppression? The 120 ohm makes sense as the 5.1vdc CIP bus is effectively riding on CAN.
What could go wrong?...
In the interest of us all learning - take one for the team and try it!
G.
__________________
Old March 6th, 2018, 07:11 AM   #7
LoganB
United States
LoganB is offline
Great info Ken! I will try and test this today and let you guys know what happens!
__________________
Old March 6th, 2018, 08:27 AM   #8
LoganB
United States
LoganB is offline
Welp, was not a perfect test environment. I didn't have a 120 ohm resistor on hand, so I had to use two 220 ohm resistors in parallel, though not sure if 110 ohms is close enough to work (should work within the range of 108-132 ohms iirc?). I was able to get the IO to be happy for about two seconds, then the resistor pin slipped off the plug pin, and I wasn't able to get it to work again. If I can get my hands on a 120 ohm resistor and maybe a spare 16 pin female plug to make it easier to keep contact with the correct pins, I will attempt this again! If anyone else tries, let us know what you find out!
__________________
Old March 6th, 2018, 09:05 AM   #9
AustralIan
United Kingdom
AustralIan is offline
These guys are selling 120ohm resistors and 16 pin female plugs.
https://uk.rs-online.com/web/p/plc-accessories/6987556/
Old March 6th, 2018, 09:11 AM   #10
LoganB
United States
LoganB is offline
No issue finding the hardware itself! I'll just have to do it at my lab instead of at my work. My boss has minimal patience for "projects" that he doesn't assign himself
__________________
Old March 6th, 2018, 11:55 AM   #11
unie01
United States
unie01 is offline
interesting thread, I also have the same question[IMG]http://*************/buluhidung/36/o.png[/IMG]
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1769 AENTR comm's on power cycle John Morris LIVE PLC Questions And Answers 16 August 3rd, 2017 05:33 PM
1769 SM 2 Module Programming (Mod Bus) Shrey LIVE PLC Questions And Answers 0 July 8th, 2013 05:25 AM
micologix 1100 & 1769 IF4 (analog) CB_182 LIVE PLC Questions And Answers 8 February 13th, 2009 11:16 AM
Lost Ethernet option link from a 1769 L35E captain_fracasse LIVE PLC Questions And Answers 7 October 2nd, 2008 02:23 PM
Ml1500, 1769 If4i Thomas Franklin LIVE PLC Questions And Answers 2 December 1st, 2006 04:04 PM
