plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 6th, 2018, 09:04 AM   #1
cdnewman
United States
cdnewman is offline
Question FTView SE & ME
Morning Folks!
I came across an old VersaView HMI that appears to be running FTView SE and not ME. My experience with A/B doesn't date back quite that far and I am wondering what I'm up against. I need to make some changes to the HMI and all I have is ME software. Any help would be greatly appreciated.
Old March 6th, 2018, 09:12 AM   #2
LoganB
United States
LoganB is offline
Did you mean, "All I have is ME software"? Otherwise I'm confused...
__________________
Present: Controls Engineer
Future: Skynet Engineer
Old March 6th, 2018, 09:58 AM   #3
cdnewman
United States
cdnewman is offline
Yes I did. I edited my original question. Thanks for the catch.
Old March 6th, 2018, 10:05 AM   #4
jstolaruk
United States
jstolaruk is offline
It could be running ME station in which case you could make changes with ME Studio but you need to dig into a little deeper.
__________________
"You can live to be a hundred if you give up all the things that make you want to live to be a hundred." Woody Allen
Old March 6th, 2018, 10:09 AM   #5
LoganB
United States
LoganB is offline
If it's running SE for sure, you will need SE software to make changes. The software itself isn't really all that different from ME, though there are a lot more capability with SE. It's almost certainly running as a standalone SE application, but I don't know of any way to make changes other than getting your hands on a copy of SE...
__________________
Old March 6th, 2018, 10:16 AM   #6
cdnewman
United States
cdnewman is offline
OK, so it's running ME Station, rev 3.1. I have FTView Studio Machine Edition software.
Old March 6th, 2018, 10:45 AM   #7
jstolaruk
United States
Quote:
Should be good to go, just got to locate the folder where the runtime file is stored so that you can make changes.
__________________
Old March 6th, 2018, 11:04 AM   #8
LoganB
United States
LoganB is offline
If you can exit the runtime and click the "load application" button in ME station, that should show you the last area you loaded from. Copy the .mer file to your PC that has Studio ME, and use the application manager to restore the runtime application. If your PC is x64 bit, you will need to use the legacy tag database converter to convert the project's tag database before you can open it (but after you restore it), but know that once you do that you WILL NOT be able to restore the program from a runtime in the future. This is the case with ANY runtime created on a x64 bit station for a platform running firmware 5.10 or older.
Make sure you make an APA of the project to back it up after you've converted it.
__________________
Old March 6th, 2018, 11:10 AM   #9
cdnewman
United States
cdnewman is offline
I've tried that approach. I get a pop-up that says the "Runtime App was saved in an older format that does not support conversion to a development application."
Old March 6th, 2018, 11:12 AM   #10
LoganB
United States
LoganB is offline
Is your studio station x64 bit? Or x32?
__________________
Old March 6th, 2018, 11:13 AM   #11
cdnewman
United States
cdnewman is offline
Win7 32
Old March 6th, 2018, 11:18 AM   #12
LoganB
United States
LoganB is offline
You get that message when the .mer is created with the option "Never allow conversion" selected. Unfortunately, at least to my knowledge, there is no way around this protection.
If you don't have an APA, you may end up having to rebuild the program yourself...
__________________
Old March 6th, 2018, 11:45 AM   #13
Dravik
United States
Dravik is offline
The OP mentioned ME Station 3.1, You couldn't convert applications from before version 5 iirc.
Old March 6th, 2018, 11:49 AM   #14
cdnewman
United States
cdnewman is offline
Ahh, so the plot thickens. I have an apa from a sister machine, but it's been upgraded to a PVPlus running ME 7.0. So from what I'm reading, it may be time to junk the VersView and replace it with a PVPlus and build a new runtime from the sister machines APA. Does that make sense?
Old March 6th, 2018, 11:50 AM   #15
LoganB
United States
LoganB is offline
If that's the case, he's definitely going to be SOL without either a file structure or an APA...
Is there a temporary file structure created on the versaview when it's RUNNING the mer? I seem to remember being able to copy some .gpx files from a PC that was running station one time to take a shortcut in rebuilding a program, but it's been years...
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FTView SE - Indirect Addressing ASF LIVE PLC Questions And Answers 2 October 19th, 2017 05:39 PM
Omron CQM1 CPU21 & FTView SE Cwz90 LIVE PLC Questions And Answers 5 February 4th, 2016 05:35 AM
Restore FTView SE 5.1 Network Distributed junior LIVE PLC Questions And Answers 8 July 14th, 2015 06:05 PM
How to create VBA function to use in Events in FTView SE nikhilec2007 LIVE PLC Questions And Answers 0 January 6th, 2015 06:16 AM
FTView SE Distributed vs. FTView Station whatplc LIVE PLC Questions And Answers 0 July 2nd, 2014 12:43 PM
