plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 6th, 2018, 02:38 PM   #1
doug2
United States
doug2 is offline
AS-i 31 vs 62 node
Can a valve with a 62 node capable AS-i top be used on a 31 node AS-i network?
Old March 6th, 2018, 04:18 PM   #2
Paully's5.0
United States
Paully's5.0 is offline
Who's valve?
You'd probably have to check their documentation to be for sure, I don't know if node 31 address of 20 is equivalent to 62 address of 20A. From a "bits and bytes" perspective, it might be but probably best to page through the manual. Or call their tech support.
Old March 7th, 2018, 01:46 PM   #3
Dirt
Sweden
Dirt is offline
"In order to retain full forward and backward compatibility, the size of the data frame exchanged between the network master (Scanners and Gateways) was not increased. Instead, one of the four output bits was used to select between the so-called A and B nodes. This enabled each of the 31 addresses to be used twice. The address space was increased to 1A to 31A plus 1B to 31B."
https://en.wikipedia.org/wiki/AS-Int...,_Version_2.04)
Seems that version 2.04 (31 nodes) are compatible with 2.11 (62 nodes) but maybe not later version 3.0?
As Paully said, check the documentation for your valve. And network master/gateway.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
trouble with 1769-SDN devicenet scanner - lost Omron NE1A node bboytaktix LIVE PLC Questions And Answers 1 August 2nd, 2017 01:42 PM
changing node# ML1000 PLCnovice61 LIVE PLC Questions And Answers 10 June 5th, 2015 08:17 AM
Micrologix 1200, can't change controller node Tim James LIVE PLC Questions And Answers 5 July 18th, 2012 11:40 AM
DH485 Network node questions matthew1 LIVE PLC Questions And Answers 3 February 26th, 2012 03:40 PM
e-mail server node 249 and node 251 cchuang LIVE PLC Questions And Answers 0 June 11th, 2010 10:44 AM
