Micro800 shared tags
zze110
Aug 2017
USA
Greetings all,
Wondering if produced consumed tags can be setup on a micro800 PLC?
I'm trying to link 6 PLC's together so they have a few shared variables (global site alarm, local system alarm, etc). Only link between them is ethernet switches.
Was looking at using a CompactLogix 5380 to solve this one but I'd prefer something cheaper for the simple tasks I'm trying to run.
Replacing a moscad rtu system where the current setup allows "shared" tags between all devices.
Ideas? Thanks!
Thank you Brendan! That sounds like what I am looking for...
We have an andon system with roughly 125 input, 125 output points (across 6 RTU's) on our lines. The moscad boxes capture an operator pressing the assistance button and relay it to a supervisor at a Wonderware HMI. Each line has its own RTU and HMI display for a supervisor. Each line supervisor must have a HMI visual when a neighboring line has an issue.
I realize there are many other (higher level) methods of doing this besides a PLC, but our company wants a drop-in replacement and they consider this process critical.
Thanks for the suggestions!
My company built a small test machine using a Micro800 PLC and CCW software. We chose the Micro800 because the machine is very simple. We are...
186
Hi, Is there a way to set the IP of a micro dynamically, based on a variable value.?
171
Anyone use the newer 2080-L50E or L70E with 1734 Point IO yet? I have a customer asking for a setup and I have not found anyone that has done...
395
Is there a way to download the program to a Rockwell Micro810 without using the Rockwell CCW application?
752
Hi All, I am having trouble converting a real to string and keep it to 2 decimal places. I'm sure its a simple solution. Any help is appreciated
306
