still can't find the right vfd
ganutenator
May 2002
kansas
1,440
the ATV 312 worked perfectly. sans programming software and manual
their 320 replacement doesn't. can't follow a 1.27 sec decl ramp.
customer is against ABB and AC Tech.
Any suggestions?
From your post, I gather that the ATV312, software and cables worked.
you now have an ATV320 replacement.
Can you manually program it and does it work?
is there a new software version and software drivers?
different interface cables?
have you tried installing the software on another pc?
just making suggestions based on experience and hope this helps.
james
Why is the configuration IP different from the actual IP address still able to run normally?
828
Just started working with some HART loops and I'm trying out Pactware.I'm using Krohne and it works just fine recognizing my modem. I downloaded...
1,352
Square D had a group that wanted to develop PLC compatible power monitoring. They worked out of the Cedar Rapids circuit breaker plant - before...
826
When a servomotor is stopped, are its three windings supplied equally with the same voltage value or close values? The servodrive is supposed to...
1,386
We have this sub-system that was installed back in 2009, was never used, the building that used it was shutdown shortly after installation, and...
1,161
