CompactLogix High Speed Input Card
Jsu0234m
Apr 2013
Alabama
94
Everyone,
I have an application where I need to pump a varying weight(depending on recipe) into a tank. I can't use the load cells on the tank because the mixer has to run the whole time which causes the tank to fluctuate more than my recipe tolerances allow.
So I decided on using a IFM SP9601 flow sensor(1.3-80gpm) that will give me 100 pulses/gallon which is more than accurate for what i need (+-2 lbs is within recipe tolerances).
The problem I'm having is I don't know if my input card will read fast enough to count the pulses. Quick math 1gal/100pulses, pump is roughly 30gal/min, roughly 50 pulses/second that i need to be able to measure.
I think I'll probably need a 1769-IQ16F which is a high speed input module but i don't know for sure if it will read a 50hz signal.
This is the first time I've had to deal with high speed inputs, so i don't know what spec i should be looking for on the datasheet. I attached it for reference.
Any help would be greatly appreciated. Thanks again.
Take a look at the digital filtering. It appears to be delectable between 0s to 2ms. 2ms is 500hz, more than good for a 50hz signal. But, you may want to look at the HSC card for this application.
I am using a 1769-IQ16F for a pulse train of up to 100 pulses per second with no missed pulses - but I have used screened cable for the input .
Paul
Team, I have a 1769-L24ER-QBFC1B and I am using the High Speed Counter. The application is fairly simple. I have a 1024 PPR encoder on a material...
1,300
Hello Everyone, Just starting on a Allen Bradley 1769l27ER and components.want to control panasonic servo drive,so output speed should be 20khz,so...
2,663
Hi everyone, i have a compact logic 1769-L18 PLC and I'm using FTalk View ME for the display. I wanted to do some visualization on Grafana. At...
82
Does anyone know what the data transfer rate for this series of CompactLogix PLC's? 1769-L24ER-QB1B to be exact. Cheers.
85
Does this instruction calculate values during a single scan, or does it require number of scans based on element count in the array? For Example...
104
