plc storereviewsdownloads
Go Back - Interactive Q & A > - Interactive Q & A > LIVE PLC Questions And Answers
PLC training tools sale
Thread Tools Display Modes
Old March 7th, 2018, 11:15 AM   #1
Tim Ganz
United States
Tim Ganz is offline
Usage Column Logix 5000
How can I use the usage column in Logix 5000 v20? In the tag editor it is grayed out or is there a better way to see what tags are used in the program short of doing and xref on each one? The usage column is grayed out in the monitor and edit tab.
Old March 7th, 2018, 11:45 AM   #2
United States
A_G is offline
Go to Controller Tags (or Program Tags if you want to see Program Tags usage). Go to the top of the window where it says Show. Click on the dropdown menu. Select Configure. Select Filter On Unused. Click Ok. This will show only Unused tags
Old March 7th, 2018, 11:50 AM   #3
nhatsen is offline
From the RSLogix 5000's help:
Usage. Available only for an Add-On-Instruction and Equipment Phase scope. For Add-On Instructions, usage is Local, Input, Output or InOut. For Equipment Phase tags, usage is Input, Output, or Normal. The default usage for an Add-On Instruction tag is Local, and the default Usage for an Equipment Phase tag Normal. Usage appears dimmed for members of tags.
So "usage" is not "cross reference". If you want to do a cross reference, select the tag (in the tag monitor or in the logic and press CTRL+E).
"If you can't solve a problem, then there is an easier problem you can solve: find it." (George Pólya)
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
GSV Wall Clock in RS Logix 5000 - Compact Logix L32E alive15 LIVE PLC Questions And Answers 11 February 3rd, 2016 02:17 PM
Addressing modes for output module in control logix 5000 kbn_120184 LIVE PLC Questions And Answers 5 August 20th, 2012 06:33 PM
Resetting Digital Input module automatically from RS Logix 5000 hasan_ali LIVE PLC Questions And Answers 3 October 1st, 2009 05:39 PM
Rs Logix 5000 training Maintenance Man LIVE PLC Questions And Answers 1 January 15th, 2009 12:13 AM
Wonderware And Logix 5000 Tom Gieschen LIVE PLC Questions And Answers 10 January 26th, 2007 10:03 AM
