plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 7th, 2018, 12:32 PM   #1
EricBig
United States
EricBig is offline
Analog input conversion
Does any1 kno how to convert raw/proportional to lbs?
Old March 7th, 2018, 12:35 PM   #2
danw
United States
danw is offline
danw's Avatar
raw/proportional what? Which units?
Old March 7th, 2018, 12:36 PM   #3
Bullzi
United States
Bullzi is offline
Need a lot more info.
What PLC are you using?
What Analog card are you using?
What type of signal? 4-20, 1-5v, 0-10v?
__________________
There is never enough money to do it right but there is always enough money to do it again.
Old March 7th, 2018, 12:43 PM   #4
Steve Bailey
United States
Steve Bailey is offline
Steve Bailey's Avatar
You need to provide at least two more pieces of information. First the minimum and maximum raw or proportional values. Second, the minimum and maximum values of pounds corresponding to those two raw values. Ok, I guess that's four pieces of information.
That will allow someone to give you an example of how to perform the scaling operation. With information requested by Bullzi, someone can come up with how to do it with the equipment you're using.
Old March 7th, 2018, 12:44 PM   #5
Mickey
United States
Mickey is offline
Mickey's Avatar
See txt.. while you are answering the other questions.
There are probably instruction(s) in your PLC to do this or scaling it in the analog card configuration(depending on the PLC,software and card you have).
Edit: the OP's other post. ( not much help there though, at least not for me)
http://www.plctalk.net/qanda/showpos...46&postcount=1
File Type: txt ScalingFormula.txt (205 Bytes, 24 views)
__________________
Mickey
If you want happiness for an hour-take a nap. If you want happiness for a day-go fishing. If you want happiness for a month-getmarried. If you want happiness for a year-inherit a fortune. If you want happiness for a lifetime-help someone else.
----- Chinese Proverb
Old March 7th, 2018, 12:55 PM   #6
EricBig
United States
EricBig is offline
Analog input card 1769 AB
0-10V
max => 31206 raw/p data
min => -31206 raw/p data
Old March 7th, 2018, 12:56 PM   #7
EricBig
United States
EricBig is offline
0-10V
Old March 7th, 2018, 12:57 PM   #8
EricBig
United States
EricBig is offline
0-10V
min pounds 5lb
max pounds 100 lb
Old March 7th, 2018, 01:02 PM   #9
Mickey
United States
Mickey is offline
Mickey's Avatar
1769-??? (which one? it does matter)
And PLC?
__________________
Mickey
Old March 7th, 2018, 02:03 PM   #10
Bullzi
United States
Bullzi is offline
From the manual that I looked at for the 1769 Analog I/O your range is:
0V = 0 Counts
10V = 31206 Counts
So if you are using a CompactLogix PLC you can download the SCLP AOI from the Rockwell website and use that. If you are using a ML1500 you will have the SCLP instruction available to you.
These instructions will scale your 0-31206 to 5-100lbs you are asking for.
__________________
Old March 7th, 2018, 02:18 PM   #11
EricBig
United States
EricBig is offline
Quote:
And PLC?
Mickey:
model# 1769 Allen Bradley (Analog Input card) IF4
0-10 volts
Old March 7th, 2018, 02:21 PM   #12
EricBig
United States
EricBig is offline
0V = 0 Counts
10V = 31206 Counts
That is a good information i appreciate the effort.
this in case of min and max (lbs)
what if i want to convert volt to pound
so when i press on the scale it measure in volts over my analog input card.
will SCLP instruction help as well?
Old March 7th, 2018, 02:51 PM   #13
lfe
France
lfe is offline
If 0V = 0 raw = 5lb
10V = 31206 raw = 100lb
then
lbs = (raw * 95 / 31206) + 5
__________________
Suppanel HMI
Old March 7th, 2018, 02:58 PM   #14
Mickey
United States
Mickey is offline
Mickey's Avatar
Quote:
Originally Posted by EricBig View Post
Mickey:
0-10 volts
WHAT PLC are you using CompactLogix or ML1500?
__________________
Mickey
Old March 7th, 2018, 03:04 PM   #15
EricBig
United States
EricBig is offline
CompactLogix
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Micrologix 1400 analog input or 1762-IF4 eccan LIVE PLC Questions And Answers 2 July 26th, 2010 06:32 PM
Analog Input as Multiple Digital Input 69FIREBIRD LIVE PLC Questions And Answers 15 July 6th, 2010 04:28 PM
Analog Input With Potentiometer HELP!! zmanvortex LIVE PLC Questions And Answers 26 May 11th, 2006 08:14 AM
Logic Question : Tracking Parts knichols LIVE PLC Questions And Answers 26 November 16th, 2005 11:34 PM
AB Analog Input Help GTX LIVE PLC Questions And Answers 2 December 14th, 2003 02:37 PM
