plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old March 7th, 2018, 07:32 PM   #1
Beau79AU
Australia
Beau79AU is offline
SoMachine Basic Modbus IO Scanner
Does anyone have any examples on how to use the Modbus IO Scanner on the Schneider M221 controller?
I have one on test bench with a Delta VFD-EL i want to control. I cannot get my head around how to set it up and communicate. The documentation isn't exactly easy from either Schneider or Delta.
Regards,
Beau
Old May 18th, 2018, 05:01 AM   #2
Blevine
United Kingdom
Blevine is offline
Up! Would be helpful for me too!
Old May 18th, 2018, 09:00 AM   #3
Engineer_MG
United States
Engineer_MG is offline
Engineer_MG's Avatar
1. Setup IP address of M221
2. Enable Modbus TCP IO Scanner
3. Setup Generic slave with IP address
4. Setup channels for the slave
5. You will see the IOScanner registers once the channels are setup
6. Use those registers to control your drive, check status etc.
7. For more information - SoM Basic help file -> Programming -> Network objects -> IOScanner objects
I have attached some pictures.
Also, you will need a minimum functional level of 6.0 to use the Modbus TCPIO Scanner.
If you are using Schneider ATV drives then we have pre-built function blocks to run the drives.
Hope this helps.
Thanks.
__________________
Ms. Mohua Ghosh
Senior Application Design Engineer
Schneider Electric , USA
Old May 18th, 2018, 09:12 AM   #4
Blevine
United Kingdom
Blevine is offline
Hello,
I have mine now working for Serial IO Scanning, getting data from an Access Point. Do you have any documentation or procedure on working with an M221 PLC and an Access Point connected to 10 devices possibly without IO Scanning?
Thanks!
Blevine
Old August 14th, 2018, 12:54 AM   #5
QasimFSH
Australia
QasimFSH is offline
How to input the Unit ID?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
SoMachine Basic instruction help (MOVE ?) geniusintraining LIVE PLC Questions And Answers 7 June 29th, 2018 03:13 AM
SoMachine Basic INT_TO_REAL onkalolo LIVE PLC Questions And Answers 5 August 2nd, 2016 05:37 PM
symbol scanner and ab basic module Paul Eagen LIVE PLC Questions And Answers 5 October 21st, 2013 09:18 PM
Modbus Serial Remote IO TimothyMoulder LIVE PLC Questions And Answers 9 April 6th, 2005 05:45 AM
PLC5-SLC IO Scanner Fault OkiePC LIVE PLC Questions And Answers 3 April 4th, 2005 08:15 AM
