Resistance AND Hipot test
BachPhi
Dec 2007
Los Alamos
640
I have an application that I need to check the coil of injectors. I’d like to check resistance of different models ranging ( 0.5Ω – 2.0 Ω) AND then hi-pot testing with 1000 VDC. I will have a PLC to interface with it.
Do you know of such unit that will do both test. Thank You.
Hi all! I have an application where we have a industrial trailer (ie: connected to a commercial truck / cab). The trailer will have some...
1,183
Can I use the resistance measurement in an un-powered compression load cell to “estimate” the load on it? I have four that are physically...
1,477
Good Morning , Just wondering . I understand that millivolts change when temperature rises . Does resistance change also ? Thanks in...
2,510
This week I was at a plant when a machine blew one of its main 100A fuses. I was helping troubleshoot this problem. I started by ohming the lugs...
17
5,480
Hello everyone! I need change a machine, use a Frequency AC drive and a brake resistance, .the AC drive model is 22A34P0N104(AB. PowerFlex...
1,630
