Modicon m580 causing network issues
Engrlife
Aug 2017
British Columbia
41
I have an m580 thats been running for about 2 months now, yesturday after a day of some small programming changes the citys network is being brought down when ever the PLC is plugged in. I have tried changing the 2 IP addresses and doesnt change anything. Not sure what would be causing this.
How are your network ports configured? The m580 supports RSTP. However if 2 ports are plugged into a non managed switch then you could have issues. Has anything changed with the cabling?
Check your updated code! it is probably executing an incomplete operation, thereby timingout and dropping the network. Is your updated code reading or writing something? Make sure the function block your implementing is specified for single word, double word or whichever, using the wrong function block to read or write large data will timeout the network.
Are the EtherNet two independent networks? Make sure to use an EtherNet switch that is dedicated for this purpose. If you have a managed switch, it can help you to trace where the timeout is coming from.
anytime I've plugged something in and brought down the network it was because I had created a loop and RSTP wasn't enabled, or some proprietary ring protocol was being used but it got a loop where it wasn't expecting it.
Are the two ports bridged thereby creating a loop in the M580?
What if you only plug in one port at a time?
Hi all, I'm really new to this. I need to export the Modbus register mapping from a Modicon M580 through Control Expert for the registers that...
950
We are now planning to upgrade from Quantum 140CPU11303 to Modicon M580. The software protect was written by Proworx NxT (.DCF). Is it possible...
1,002
Hi, Does anyone know if programming a Modicon M580 is basically the same format as an M340? Also do they use the same software package? Thanks...
1,776
I need to convert some Siemens PLC logic using Siemens TIA V16 to Modicon M580 logic. Is there a tool out there that will get me started? How...
2,687
How do you go about implementing, on the M580 PLC, how many days, hours, minutes before a predefine event in the future? The RRTC_DT yields the...
1,814
