ABB PM581 printout needed
goghie
Jan 2008
Belgrade
800
Hi!
I have source code one disc from one machine with ABB PM581 PLC, and I don't have software and I don't know which one should be used.
Would anybody be kind enough to make printout - I will send source privately. It's quite urgent as I need to convert it to another PLC made by different manufacturer.
Thanks in advance.
Best regards.
I did some quick research on the file structure of the SD Card copy you sent and found the following link:
http://www.infoplc.net/files/descargas/abb/infoPLC_net_AC500_SD_Rev_3_2.pdf
It looks like in order to have source code, the SD Card should have had a folder called "USERPROJ", but your zip file did not contain this directory. It looks like the USERDAT and USERPRG folders are compiled versions of the code, from which you cannot extract the source code.
Hopefully someone more experienced with this ABB model and software can shed more light on this.
Thank you for your info. I see now that it is Codesys, strange that there is no "SOURCE.DAT".
does anyone have an install or know if/where i can download it for the following "ABB PS501 Control Builder Plus V2.3 " the software was a free...
85
Hello, It is mandatory to use VFD IF i use IE5 electrical motor? What happens If connect it directly as delta without VFD? Please look at motor...
131
Hi hoping someone can assist me with current issue I am experiencing with an ABB drive. Problem I’m experiencing is a ABB drive supply a large...
207
Hello all, I have an ABB PLC (PM573) and it has without MC card. I need to take backup from PLC to PC (in automation builder v2.7 ). My...
429
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
178
