plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 3rd, 2005, 04:54 AM   #1
lc03
United Kingdom
lc03 is offline
lc03's Avatar
RSLogix 500 activation
Hi all,
I have a bit of a problem here this morning,
I have been called to a job, at a site I have not attended for over 8 months, to look into a 'program' fault with one of the machines.
On starting up RSLogix 500 I was greeted with the message:
FATAL ERROR!
THE COPY PROTECTION LICENSE FOR THE APPLICATION COULD NOT BE ACQUIRED.
ERROR: 2
After much head scratching, I can only imagine that the IT dept. have been doing a disk cleanup or something (no one else has access to this PC).
I have RESET the activation on the master disk, hoping to transfer it to the hard drive.
But when I try to transfer, I get the message:
ACTIVATION FILE CORRUPT - INVALID SERIAL NUMBER
(This IS the master disk that came with the software before you ask!)
I have no manuals or contact numbers here on site with me, can anyone help?
Old January 3rd, 2005, 05:00 AM   #2
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
Rockwell Automation UK:
website: www.rockwellautomation.co.uk
telephone support: (0) 870 241 1802
__________________
Jesper
3 strikes and you're out
Old January 3rd, 2005, 05:04 AM   #3
lc03
United Kingdom
lc03 is offline
lc03's Avatar
Thankyou JesperMP,
I have discovered since posting that the software will run with the master disk in the floppy drive, even without transfering the activation. In my blind panic I wasn't thinking straight!
Seem to remember the software won't run like this forever though?
Old January 3rd, 2005, 05:11 AM   #4
Bob O
United States
Bob O is offline
Here is the US numbers...Don't know if it is going to help.
[attachment]
There is also away to set the computer to look at the "A" [floppy drive] for an activation disk and start RSLogix even without an activation key. You may have to search the Rockwell site for that info.
For the Heck of it.....
Have you tried putting the activation disk in and then try to start RSLogix?
Good Luck,
Bob
Edit...
lc03
The software will run like that until RSLogix is shut down. Glad you got it.
Old January 3rd, 2005, 05:43 AM   #5
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
I've had this happen to me, usually caused by a disk defragmentation program.
You have to remove the current corrupt activation, then re-activate the software.
Do a search for: EVRSI.SYS & 386SWAP.PAR, delete these files, then try moving the activation. You may have to reboot between deleting and moving
A work around is:
If you have multiple partitions, and one is bad, you can install activation on different partition.
Ken
__________________
"To give real service you must add something that cannot be bought or measured with money; and that is sincerity and integrity."
- Donald A. Adams
Old January 3rd, 2005, 09:50 AM   #6
lc03
United Kingdom
lc03 is offline
lc03's Avatar
Thanks Ken,
I have searched for these files and cannot find them, but still no luck with moving the activation.
How can I remove the current corrupt activation?
Why is this so complicated ??
I guess i'm gonna have to call AB banghead
Old January 3rd, 2005, 10:19 AM   #7
john paley
United States
john paley is offline
john paley's Avatar
If you lost the key from the hard drive, you won't be able to load another from the floppy until it is reset by Rockwell. I've done this before. They tell you where to find the files to delete, then give you a code number that will add one install to your floppy, then transferred to your hard drive. Your gonna have to call them in any case.
By the way, I think you can use the floppy in the A: drive forever with AB. I think I remember Siemens having some temporary usage setup for lost keys, though.
__________________
The Big Cheese
Old January 3rd, 2005, 10:32 AM   #8
Ken Moore
United States
Ken Moore's Avatar
The files are hidden files, so you have to select the show all files option. They are usually located on the root directory.
C:\ for instance.
The swap file will not be present on NT based products, such as Win2k, and WinXP.
__________________
- Donald A. Adams
Old January 3rd, 2005, 10:34 AM   #9
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
That's more evidence that your IT department is at fault; they've either removed the activation files or have made them "hidden" such that you don't have the rights to see them. If the software was once licensed on that computer, it's certain that the EVRSI.SYS file is there too.
It's an old and clunky activation system, but RSI can get it resolved in the space of a single phone call. Go ahead and call the UK offices.
By the end of 2005 there will be a much more durable activation system in place for RSLogix, using a simple text key instead of hidden files and activation disks.
Old January 3rd, 2005, 11:08 AM   #10
mgvol
United States
mgvol is offline
mgvol's Avatar
Cool
There is one other possibility for why you are experiencing this: Is you software part of an Integrator's Toolkit? These have "timed" activation; when your contract is up, it quits working. I learned this the hard way when my old company sent the renewal payment directly to Rockwell instead of our distributor. They didn't know what to do with the check, so they just deposited it and our licenses expired anyway. If this is the case, and you are going to "legally" renew, you can set your PC clock back a couple of months and it will start working again.
Old January 4th, 2005, 01:44 AM   #11
Voltimus
United States
Voltimus is offline
Voltimus's Avatar
I've also reset activation through a phone call.
A couple of words of advice though;
Use the phone by the computer and have the computer running at the time of your call, that way you have quick access to the evreset program and can relay any faults that come up. If a corrupt file and the activation is your only problem, it should be a snap.
P.S. Don't go to EBay
Old January 4th, 2005, 07:21 AM   #12
lc03
United Kingdom
lc03 is offline
lc03's Avatar
Sorted!
Thanks to everyone who replied:
I have now found the offending files:
386SWAP.PAR
evri.sys
and removed them, after a re-boot I was able to transfer the activation (which i had already reset online).
Old January 6th, 2006, 07:07 PM   #13
Ken Roach
United States
Ken Roach's Avatar
Thank goodness for PLCTalk.net !
This issue came up again to me this Friday afternoon just before the end of the workday, with a customer who needs to get on a plane this weekend with his newly-activated software. For the life of me, I could not find the corrupted EVRSI.sys file.
I googled this thread from somebody else's computer, and it reminded me that you need to change the Folder Options not only to show hidden files, but also to show hidden operating system files (because Windows considers .SYS files to be OS files). That allowed me to find and delete the EVRSI.SYS and 386swap.PAR files and re-load the fresh activations.
Old January 20th, 2008, 11:03 AM   #14
Lancie1
United States
Lancie1 is offline
Lancie1's Avatar
Quote:
...you need to change the Folder Options not only to show hidden files, but also to show hidden operating system files (because Windows considers .SYS files to be OS files).
For that reason, I always change the "Folder Options View" on whatever computer I am using for programming to "Show hidden files and folders" and uncheck the boxes for "Hide protected system operating files" and "Hide extensions for known file types".
However the IT department comes through and changes it back and locks up access so that I am again dead-in-the-water if anything goes wrong. Nowdays, when it comes to computers, no one trusts anyone else not to screw up the system. That is propagated by all the companies advertising and selling protection methods - the result is mass paranoia. Grrrrrrr! Is it any wonder that I no longer go in to work unless they call me on some problem?
So-called PERSONAL computers will soon be so protected and so dependent on the IT department, that we might as well go back to using IBM 360 central mainframes with program submission by keypunch cards!
Old January 21st, 2008, 08:17 AM   #15
ashish_hal
India
ashish_hal is offline
A month back i got he same error when i dropped my laptop off the desk.i simply started with the installation again .......................and that ask me for three opions.
1) Modify
2) Repair
3) Remove
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
where down load demo RSLogix 500 software? dyan256 LIVE PLC Questions And Answers 18 June 6th, 2013 07:24 AM
Shifting I/O Modules, Slots: RSLogix 500 Question mbd0722 LIVE PLC Questions And Answers 8 February 4th, 2012 04:56 PM
RSLogix 500 Vs. RsLogix 5 mrdmrd LIVE PLC Questions And Answers 7 February 21st, 2005 05:11 AM
Installing RSlogix 500 Activation File krobertson LIVE PLC Questions And Answers 7 July 3rd, 2003 12:44 AM
RSLogix 500 Activation godfrey LIVE PLC Questions And Answers 1 October 5th, 2002 10:30 AM
