omron plc serial to ethernet conversion, using serial to RJ45 converter
karthiknd7
Apr 2017
20
Is it possible converting Omron and Keyence plc's serial communication into Ethernet using serial to RJ45 converter?
I need to connect these plcs with MOXA 5600 terminal service for communicating it to the Server.
Thanks in Advance....!
No, you will need to know the pin out of the serial port on the PLC and you will need to match that to your MOXA, a standard adapter (odds are) will not work
Serial and Ethernet are two very different communication mediums and can't be connected by way of changing the pinout of a connector. On top of the communication layer is the protocol which is the language that devices speak and that also needs to be either bridged or converted (bridging is easier). You need something designed specifically to bridge the specific serial communications protocol for each device (assuming they are different protocols) to the appropriate Ethernet protocol.
The MOXA 5600 series is a protocol converter (RS232/422/485 to Ethernet)
All they need is the pinout
Hello, I am building an application in CitectSCADA and I want to communicate with an Omron Sysmac CS1G. The connection between the plc and the...
1,423
Hi, I need get some data from a Omron PLC, model SYSMAC C200HX, this is an old plc that only have a serial port RS-232C. The fact is I need to...
4,258
Hey all, This is a great site. I'm fairly new to PLC programming, but learning quite quickly. My issue is that I don't know where to begin with...
7,739
I am having trouble sending a ascii string of information from an Omron PLC to a PLC 5\40. I am connected to channel 0 and the PLC is configured...
17,392
D
I have recently recieved a new laptop from work which doesn't have a serial output. This was remedied by using a USb-serial driver. For some...
5,580
