Connected Components Work Bench Micro 800 PLC Modbus Mapping
Sep 2016
Jeddah
24
Dear all,
In CCW modbus Adress mapping where each adress is configured in modbus mapping option.For example I will be mapping some memory bit or Input Bool signals to 100001 and I am able to read the data from this adress starting from 100001.
Now my issue is I need to write data to Micro 870 through modbus.So for writing bool to Micro 870 which adress should be used?Is it like similiar to reading adress starting from 100001?
Normally in siemens I used to configure holding registers starting from 40001 but here in this I am not able to configure adress from 40001 as it is for word and I cannot segregate to byte.
Modbus "Function Codes" will determine what address range you will be (Reading/Writing) to.
CCW has several function blocks that can deal with "Expanding/Merging" bits into words or separating word value into bits.
However, you may have to download them(The function blocks) from their support web site.
was trying to use Connected Components to connect to a 525 drive via usb with the face off but can't seem to connect to it. the screen lights up...
748
So I'm using CCW to program a panel view and this is not my first I have done many. My Problem is I get an error message that I have never seen...
476
How do you expand a branch in connected components workbench. Example i want to add an interlock around more than one contact. Most software you...
1,267
I’m working on a conveyor project for work. We’re trying to install a few diverts to carry product directly to one of two trailer doors. I have...
1,037
I cannot get CCW to add a controller, i keep getting a error message saying that the device is not authorized. This happens with any model and...
1,329
