pulse generator from analog output
lesmar96
May 2017
PA
520
Good Morning, Customer has given me a PAX2D Red Lion timer to read and display the speed of a motor.
The drive only has analog outputs, but the PAX2D is built for high speed pulses. I am just curious if there is a device out there that you could recommend that would take a 0-10V output and covert it into 0-50khz pulses. For example, at 5 volts it would put out 25khz and at 10 volts it would do 50khz. These numbers are for illustration and I don't those exact specs but that is to prove the concept.
If this is not practical, i do have some other options but this would be my first choice. I can buy a PAX2A, but the customer wants the PAX2D because that is what they use all over the plant.
Any thoughts or suggestions?
Lesmar
In the past.. I used their resolver interface
I spoke to my local distributor and gave them the part number
they ordered it for me
G'day Can anyone explain what the reasons for having Square Wave Generators in a PLC code? Cheers
3,042
Very new to PLCs, I am trying to add a delay to a simple motor setup. I want the motor(just name I gave to output) to be able to go on for 5...
4,201
Does Anyone know what we should be configuring a hand pulse generator on a 1769-HSC card.I would really like to know.
2,272
Hello all, i know that subject has been already treated. But i didn't find a answer to my question. I'm noob with Rockwell PLC (i'm Siemens...
6,619
how can i generate a pulse of high frequency of range 500 Hz to 1.5 KHz with 313C i want to generate the pulses to control a stepper motor??????
3,273
