Edge trigging in ST or SCL
xzen
Jun 2006
Oslo
97
What is your best practice for edge trigging in structured text language?
Code:
#condition := (Value1 > 0 OR NOT Tag1) AND Tag2;
IF #condition_positive_edge THEN
    some_code();
END_IF;
Jesper's post 9 years ago, same as Manglemenders If condition on ST.
Dont think there is a one-shot block for SCL.
But it is trivial to code.
signal_oneshot_ON := signal_input AND NOT signal_mem ; // generate the ON oneshot
signal_oneshot_OFF := NOT signal_input AND signal_mem ; // generate the OFF oneshot
signal_mem := signal_input ; store the status of the input
Not sure if it's in all ST packages but in CoDeSys (at least in v3.5) you can set a bit for a positive or negative edge trigger. The 'P' indicates positive edge, for Negative edge it would be an 'N'
attachment.php
I have a FX3U clone that I am failing to get a simple Structured Text example working on and would really appreciate some help. I created a...
30
945
I'm trying to build my Classic Step 7 programming skills this weekend. I get stuck on little things that are not covered in YouTube tutorials. I'm...
311
Hello, I have been tasked with adding some analog signals for display and alarm setup in some old Schneider Electric HMIGTO HMI-panels. I have...
164
Good afternoon everyone, could someone guide me on how to program a falling edge in a wave micro control using CWDesigner? It is to reset a...
129
Can anyone share a way to make a button on the HMI that hits the "Ack Page" in an Alarm and Event Summary Window? or better yet - a plc tag...
264
