1734-ADN with IB8/OB8 to 1756-DNB
PunchPunchWin
Jan 2021
Home
Hi everybody,
I have with me the following:
1. 1756-L73S controller + 55L7SP safety partner
2. 1756-ENBT
3. 1756-DNB
3a. 1791DS-IB8XOB8​
3b. 1734-ADN​
3b.i. 1734-IB8​
3.b.ii. 1734-OB8​
I want to be able create tags for the 1734-IB8 and 1734-OB8 I/O modules so I can program the buttons that are wired in our circuit to these. I've gotten as far as to get steady green LED's on all my modules but only see Local:3:S/I/O and the I/O from the CompactBlock module.
What do I need to do?
These are the steps I've already taken:
- I've added Modules 1~3a to my I/O config in RSLogix5000.
- I've created a .dnt for the Subnet called "ADN Network.dnt".
- I've created a .dnt for the DeviceNetin "1756-DNB Network".
- I've clicked on the 1734-ADN module properties and associated the module with "ADN Network.dnt"
- I've then gone into RSLogix5000 and given the path for "ADN Network.dnt" as the DeviceNet file for the 1756-DNB module to link it to the ADN + its I/O.
Thanks and best regards.
PPW
You had to give the Adapter module a name, that identifies the rack, then it is just type, slot, channel.
Code:
MyRack:I:Data[2].0  for Input bit 0 on the input card in slot 2,
MyRack:O:Data[3].4  for Output bit 4 on the output card in slot 3
Code:
Thanks for that! I appreciate the explanation. I'd been struggling with understanding what the numbers represented in the terminology.
I'm grateful. :nodi:
I am a beginner on the AB platform and I have a question. I have a 1769-l32e with scanner devicenet,I am presented with the offer to buy a point...
1,714
Hello all, We have compactlogix CPU with 1769 SDN scanner. The scanner is connected to two nodes 1734 ADN .Every now and then ADN fails with...
3,596
I'm playing around with some DeviceNet stuff on my test bench and just got a 1734-ADN. I forgot the ADN was AutoBaud, so that's a nice feature...
1,627
Guys How would I configure a 1734 ADN ethernet adaptor module in device net? In the parameters dialog box, would it be an input plus all the...
1,832
I am in the process of adding a new node to an existing DeviceNet network with a SLC 5/05 PLC processor. The scanner on the main network is a...
1,419
