plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 10th, 2005, 08:19 AM   #1
RheinhardtP
Australia
RheinhardtP is offline
RheinhardtP's Avatar
S7 Data block comparisons
Hi All,
I need the CPU to compare 50 bytes of data in 2 seperate Data blocks without PG online,
I couln't find anything in any standard Step 7 blocks,
I know you can compare Real,INT and DINT but need a bit more data compared.
I though of using the XOR DWORD function which will generate a value < 1 if DWORD data is not the same, then i still have to look for value < 1 than ect., and i still have to generate x-amount of merker bits to manipulate a single bit result.
Same or Not.
Must be an easier way.
Would appreciate any feedback
Kind Regards.
Rheinhardt
__________________
“If a cluttered desk is a sign of a cluttered mind, of what, then, is an empty desk a sign?”
― Albert Einstein
www.tier16.com
Old February 10th, 2005, 09:07 AM   #2
Cuke
South Africa
Cuke is offline
Cool
Hello could you break the 50 bytes up into seperate data units like int's then add up all the seperate values to create a new value which is your new data format it could be real int dint word dword what ever and then do the oposite for the data you are compare to, so that you could see and understand what you are looking at.?????
Old February 10th, 2005, 02:21 PM   #3
USDutchman
United States
USDutchman is offline
STL Code
You could use a loop with indirect addressing, stepping though the words 1 by one, and set a flag when your XOR DWORD (or XOR WORD) command finds a difference. Off cource you reset this flag before you start the search.
I have sample code that does something very similar (Uses three DB Blocks as inputs, sets a (horn) bit when there is a difference in the first two, unless the difference was allready detected once indicated by a bit in the mask. I use this routine to find new alarms (bits) in a DB block, and sound a horn for the important new alarms (hence the mask DB). Unfortunately most comments are in Dutch, which you may be able to read if you speak afrikaans?
Old February 10th, 2005, 02:54 PM   #4
DesertDog
United States
DesertDog is offline
DesertDog's Avatar
I have not done this and it would probably not be as simple as this but how about something along these lines:
Take the first byte of each block in as a pointer. Start a loop that reads in the pointed value & compares, Saves the result, an increments the pointer.
__________________
Glenn
MCP, MCSE, MCDBA
If I can't fix it*, it ain't broke.
*With the help of PLCS.net
Old February 11th, 2005, 08:39 AM   #5
Progger
England
Progger is offline
compare
hello,
you wish this function?
http://www.sps-concept.de/download/print/cmp_area.pdf
progger
Old February 14th, 2005, 12:37 AM   #6
RheinhardtP
Australia
Looks right
Hi progger,
yes, this looks like the one i need, searched on the Simens website but couldn't find it, any way you can help me get hold of this one??
Regards
Rheinhardt
__________________
― Albert Einstein
www.tier16.com
Old February 16th, 2005, 07:38 AM   #7
Progger
England
Progger is offline
siemens
its not from siemens!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
MPI comunication Manuel Raposo LIVE PLC Questions And Answers 22 July 16th, 2007 06:24 AM
AB SLC505 Remote I/O 1stwave LIVE PLC Questions And Answers 4 August 15th, 2004 09:56 PM
S5 Data Block teh LIVE PLC Questions And Answers 2 August 3rd, 2004 03:51 PM
Building an S7 Array Move Questions DesertDog LIVE PLC Questions And Answers 19 June 17th, 2004 09:51 AM
data share betwwen two s7 plc... how to share and configure it..? teh LIVE PLC Questions And Answers 1 March 29th, 2004 02:57 AM
