plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old February 17th, 2005, 03:53 PM   #1
mmw
United States
mmw is offline
mmw's Avatar
RSLinx / Controllogix problem
My NT4.0 box running RSLinx 2.42.00 (build 18) will not allow me to browse past a 1756-ENBT module. I can "see" the ethernet module in RSWho, but when I click on the "+" to expand and drill into it, the "+" changes to a "-" (as I expect) but then just sits there and looks dumb. The driver Diagnostic Event Log has an entry stating "Can't read port type: no Harmony object for this Ethernet". I have already tried deleting the two harmony files, mentioned in one of Rockwell's tech notes. Not sure which direction to try next. Anybody else had this problem? Any thoughts (thoughts = solutions)?
Thanks.
Old February 17th, 2005, 05:28 PM   #2
Operaghost
United States
Operaghost is offline
Operaghost's Avatar
Assuming you know the IP addresses of the devices on the other side of the ENBT, can you use Windows Ping utility to ping them from your PC?
OG
Old February 17th, 2005, 05:31 PM   #3
Contr_Conn
United States
Contr_Conn is offline
Contr_Conn's Avatar
Most likely you need EDS file for you major revision.
Old February 17th, 2005, 08:43 PM   #4
bobwithdana
United States
bobwithdana is offline
bobwithdana's Avatar
First off what is connected to the Ethernet module? In some cases you need to ADD the Device so that it will be there.
Also how are you connected to the PLC, In my case I connect wireless thru a network and have to put a gateway in my ENBT card.
Need more information and maybe provide some help.
Old February 17th, 2005, 10:47 PM   #5
tom_stalcup
United States
tom_stalcup is offline
tom_stalcup's Avatar
*Deleted due to saying the exact thing someone else said........ Gotta learn to read someday *
__________________
"If beating your head against the wall doesn't work, try banging a little harder. It won't help you any, but at least I'll be amused"
Old February 18th, 2005, 12:47 AM   #6
chendrixson
United States
chendrixson is offline
chendrixson's Avatar
If you are using the ethernet/IP drivers try setting up a plain ethernet driver adding the IP address of your ENBT in the station mapping configuration. Then you will have another "path" to take. we have been having trouble with this off and on for some time now. Version 2.41, 2.42, and 2.43 have all done the same thing. When Ethernet/IP locks up, I am always able to gain access through good old standard ethernet driver.
Regards,
Charlie
Old February 18th, 2005, 07:33 AM   #7
mmw
United States
mmw is offline
mmw's Avatar
Thanks for the responses guys. Let me address what many of you have suggested ...
operaghost: the ethernet module is setting directly next to a controllogix processor in the chassis. Yes, I can successfully ping the enbt.
Contr_Conn: I used the EDS Hardware Installation Tool and installed everything I could find. During the installation, the list of icons displayed the proper controllogix processor.
Bw/D: just connected on a plain ol' network ... nothing wireless involved.
chendrixon: I tried both the ethernet/ip and the standard ethernet driver, with the same results.
I have the same (RSLinx version) configuration on another pc that's running W2K and it works fine. Can drill into the controllogix chassis as needed. That's why I was suspecting that it might be an NT4.0 thing.
Old February 18th, 2005, 09:50 AM   #8
mmw
United States
mmw is offline
mmw's Avatar
problem resolved ... corrupt and some missing backplane EDS files thanks again to all (Bw/D - you pointed me in the right direction)
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
ControlLogix 1757-SRM problem ashley LIVE PLC Questions And Answers 7 March 1st, 2012 07:52 AM
SLC 5/05, RSLinx & Ethernet problem hhuong LIVE PLC Questions And Answers 6 February 6th, 2008 11:46 AM
RSLinx & DDE links Danocane LIVE PLC Questions And Answers 4 September 23rd, 2004 02:18 PM
Ab Plc5 Rio Problem. fernandes LIVE PLC Questions And Answers 5 March 7th, 2004 01:25 PM
RSLinx communication problem ashley LIVE PLC Questions And Answers 9 July 30th, 2002 06:11 AM
