siemens WinAC v3.0
Gert
Feb 2005
Hi guys
Is anyone still working with Siemens WinAC v3.0? Because I don't really don't know how to configure my pc slot with S7 HW config and the Station Configuration Editor.
Can anyone explane it to me?
Thanx
Gert
Slots and Hardware config
Hello I'm using WinAC V4.1 and have used WinAC V3.0 MP the hardware config is the same as the Station config , the importent thing to remember is the slot numbers i.e slot 1 say winCCflex then slot 2 Softplc with your connections to Dp if there are any, then in you station config you add the same thing as in the s7 hardware config(you also have to added the dp connections to the softplc in you station config??), if you are downloading to the station from the station then the name of the project and the name of the station must be the same and also you PC/PG interface must be set to internal. You could also use ethernet in which case you have to added IEgeneral to the station and to you hardware config an give an IP address the softplc goes by slot address. I don't know if this is what you wanted ?
Hi all, I'm hardly a Siemens expert, and am struggling with a conversion I'm working on right now. A system was purchased at auction, and I'm...
1,828
I have a scanner that i need to gather the barcode for my plc of a certain material. I have a S7 Winac rtx soft-plc on the machine. Usually for...
3,706
System: MP377+ET200S, WinCC Flexible 2008SP1 + Step7 v5.5 I am wondering how can I immediately refresh the ports of the I/O devices without...
1,390
I am starting a new design and I have a few options for this. I am looking at using a MP370 touch panel for the HMI. I don't need much of a plc...
5,255
Hello all! I am working on trying to use a Siemens WinAC instead of a S7-317 PN/DP when testing applications against a Beijer (Mitsubishi...
2,248
