Allen Bradley PLC 2 Communications
hitesh
Feb 2005
25
Hi all
I have a customer with a PLC2 processor - does anyone know what software Allen Bradley or otherwise can be used to program, monitor and change logic in the processor. Also would appreciate if you could tell me what cable etc would be needed.
The customer already has a PCMK card.
Also would it be possible to get an activation or copy of activation for AI software for PLC2?????
Thanks in advance
Pls check
i am sending old replay s on Plcs.net if possible pls check
Thnaks
sandeep
OLD Replys
I think you have to use one of these:
http://www.plccenter.com/Detail_New...r=ALLEN+BRADLEY
Heres the manual:
http://literature.rockwellautomatio...pm001_-en-p.pdf
I am not positive about the PLC-2, I know AB stopped supporting them several years ago. At the time they had migration tools to convert to a PLC5.
This may offer some help: http://www.ab.com/silver/plc2.html
You are correct, the PCMK and PCM/2 cable is used with the PLC-2, should have looked in my PCMK manual.
It looks like you have your facts correct.
Yes 6200 can be used....before you get too frustrated goto the AB download section. There are some tools there to help with using a PCMK on the PLC2. I believe there are also some conversion tools too.
http://www.software.rockwell.com/su...etail.cfm?ID=98
Read this about series A & B PCMK, cardware, PLC2 software:
http://domino.automation.rockwell.c...02?OpenDocument
Detailed PCMK info:
http://domino.automation.rockwell.c...32?OpenDocument
PLC2 to PLC5 conversion:
http://domino.automation.rockwell.c...3C?OpenDocument
You can get a "credit" from AB thru the Step Forward program:
Hello hitesh;
If you do a search on PLC2 in the Rockwell site (www.ab.com) you will get much information on products still supported by the manufacturer.
For comms, here is an extract fron one of those ocuments:
Hope this helps,
Daniel Chartier
TOPDOC is an option
You can still purchase TOPDOC PLC-2 at a reasonable price, with support, from the manufacturer. It is DOS software, but will run on Win95/98. It comes with a serial port cable to connect to the PLC-2 front port so no special card is needed.
http://www.softplc.com/oldtopdoc.php
A very good, and comparitively inexpensive option is the PLC WorkShop for Allen-Bradley PLC-2 made by FasTrak SoftWorks, Inc. This can be purchased directly from FasTrak, or can also be purchased through PLCCenter - Radwell International. FasTrak still supports the software and it is a far less expensive option than Rockwells offering.
Jim
[email protected]
www.fast-soft.com
Hello, I am new here. I am trying to find good places to sell some surplus items that I have that isnt through ebay. Does anyone have any sources...
334
Hi good day Everyone, I have a cimplicity v10 project with 7 to 8k tags communicating with AB PLC through OPC and Rslinx classic. I have this...
212
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
197
I have a network with 4 PLCs PLC1 is controllogix and PLCs 2-4 are compactlogix and they all need to communicate. The current way I have this...
255
Hi Everyone, I am currently trying to communicate ControlLogix PLCs via EtherNet/IP with Delta V DCS. There is a VIM2 card configured for...
260
