plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 10th, 2002, 01:09 AM   #1
ranjana
Saudi Arabia
ranjana is offline
ranjana's Avatar
Test equipment
I have a project in hand to build a test equipment for air conditioner manufacturer.
First test is conducted at station no.1 -insulation test with Hi-pot meter.
When the new A/C unit reaches station no.1. the operator at station no.1 will read the bar code printed on the compressor. the bar code is a identifier for this A/C unit. Now the bar code no. should be read by the PLC and it should store this no. and all the below test should be registered under this code no. only.
1.Test voltage in KV
2.Leakage current in mA
3.test time
Result : pass / fail after test time.
when the A/C pass the insulation test it would move for other tests.
Finally when the same A/C unit arrive station no.2 the opertor at station no.2 will read the code through another bar code reader.
Once the bar code is read the PLC should provide all the test values of this unit from station no.1.
at station no. 2 operator will read the below test values
1. Suction temperature
2. Discharge temperature
3. Fan Speed
4. power consumed
5. present supply voltage
6. current
now he will vary the voltage by +/- 20% of the nominal supply voltage and again he will check for above 6 parameters.
All these parameters should be stored under the same bar code and a report should be generated. the report will be printed and pasted on the A/C unit. Customer is planning to use VB with crystal report to do this job. so i will just provide him the values through RSlinx OEM.
So my problem starts with the bar code reader.I have used Fixed mount bar code reader in one of my previous application. That is from Microscan but in that i took only contact o/p to stop the conveyor when the product read is of different code.
But in this application customer wants only hand held bar code reader for both the station and also i have to read the no.
Now i have to get the code from both of these hand held scanners to my PLC. I would be using a PLC from AB.
Can you please give me suggetion on the type of hand held scanner(bar code reader) and the manufacturer for this application.
Your suggestion on the above will be highly helpfull.
Many thanks
Old November 10th, 2002, 06:30 AM   #2
Mr. Allen Bradley
Canada
Mr. Allen Bradley is offline
Mr. Allen Bradley's Avatar
scanner
I'm using a hand barcode scanner in my factory.
Allen Bradley
2755-G1 for gun
2755-GH1 for scanner
This product is a older product, 1986
Look at [url=http://www.accusort.com] for another type of scanner if this product is backorder.
good luck!
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Problems with Siemens CP340 RS232C communication Borte LIVE PLC Questions And Answers 10 February 17th, 2010 05:16 AM
Test Equipment rocket1010 LIVE PLC Questions And Answers 6 January 28th, 2005 03:58 PM
Information about TYPE TEST MDB? Platootod LIVE PLC Questions And Answers 3 December 2nd, 2004 10:23 AM
Commercial Ethernet and EtherNet/IP arigatuso LIVE PLC Questions And Answers 22 November 21st, 2004 04:47 PM
PLC Back-up and Restore Test Prasannna LIVE PLC Questions And Answers 2 May 28th, 2003 07:09 PM
