plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old May 19th, 2005, 02:26 PM   #1
georgeofthejungle02
Canada
georgeofthejungle02 is offline
georgeofthejungle02's Avatar
Time Preset/Accm adjustments using Logix 5000
I am just curious as to who else run into this little annoying problem.
In process control, we use timers all the time ie, adjusting filtration cycle timers etc., and the preset and accumulated value needs to be adjusted in either seconds, minutes or hours
Using panelview plus HMI, the timer preset in the logix 5000 are all in milliseconds, and I have to manually convert the hours, minutes and seconds to millisecs. I am wondering if anyone else runs into this problem. Why can't there be a built in time base convertor that automatically adjust the entered hours or minutes to millisec?
Thanks for listening,
George
Old March 27th, 2009, 01:38 PM   #2
edwardt
United States
edwardt is offline
if you are using V16 or higher, create an add-on instruction that does that for you. I have one built and wouldn't mind sharing it.
Old March 27th, 2009, 01:49 PM   #3
widelto
Colombia
widelto is offline
widelto's Avatar
Using and AOI is a good idea, but if you have no experience with AOIs you can easily multiply the value you enter in you HMI (second, minutes or hours ) times 1000, 60000, 3600000 respectively and put the results in timer.pre location as desired.
__________________
My two cents.
Old March 27th, 2009, 01:53 PM   #4
edwardt
United States
edwardt is offline
Correct. I have an instruction that will do that or it will convert miliseconds to hours:minutes:seconds. I often use those for "time remaining" functions. Basically there is a bit that you set in the instruction and it will either convert up or convert down automatically.
Old July 8th, 2011, 10:38 AM   #5
paulB
United States
paulB is offline
Edwardt,or someone else.
Do you mind to share this instruction?
Thank you,
PaulB
Old July 8th, 2011, 12:52 PM   #6
edwardt
United States
edwardt is offline
I've attached two files. One is for converting to mS, and the other is used for showing time remaining from a timer. This useful when wanting to display this on an operator interface.
Old July 8th, 2011, 01:12 PM   #7
paulB
United States
paulB is offline
Thank you
Old July 8th, 2011, 08:50 PM   #8
Plastic
United States
Plastic is offline
No ladder required
When creating the numeric entry/display at the Panelview Plus..
For Seconds, where you have the TAG for indicator, just append /1000. Where you have the TAG for the write value, add the expression *1000
For Minutes, where you have the TAG for indicator, just append /60000. Where you have the TAG for the write value, add the expression *60000
For Hours, where you have the TAG for indicator, just append /360000. Where you have the TAG for the write value, add the expression *360000.
That is all there is to it. It is much like the Panelview Standard TAG SCALE function.
Old January 25th, 2018, 04:59 AM   #9
tomthelampy
United Kingdom
tomthelampy is offline
Quote:
Amazing, exactly what I needed, Thank you!
Tom.
Old January 26th, 2018, 07:05 PM   #10
daba
United Kingdom
daba is offline
daba's Avatar
I'm just curious why the PLC code ever needs to adjust the accumulated time... ?
__________________
___________________________
ControlLogix & SLC Training
a-b train ltd.
abtrain@tiscali.co.uk
www.abtrain.co.uk
tel: 07506 73 9999
nil illegitimi carborundem
Old January 26th, 2018, 10:21 PM   #11
JaxGTO
United States
JaxGTO is online now
The Rockwell examples download page has lots of time AOI's.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Logix 5000 install problem smiller LIVE PLC Questions And Answers 16 May 26th, 2015 10:47 PM
RS Logix 5000 instruction stantana LIVE PLC Questions And Answers 5 April 9th, 2008 09:25 AM
RSLogix 5000 V15 Features Samneggs LIVE PLC Questions And Answers 18 April 20th, 2006 06:45 PM
RS Logix 5000 Licensing Question ndzied1 LIVE PLC Questions And Answers 8 March 6th, 2005 10:44 PM
