plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old June 1st, 2005, 09:40 AM   #1
alberto laville
Mauritius
alberto laville is offline
alberto laville's Avatar
Smile Allen Bradley Plc
I have my power supply card that got blown last week,and i replaced it by a new .
To my expectations this afternoon i found that the new power supply
card is not working after it has been working for three days.
The plc is powered from a UPS.
Need help.
Alberto.
__________________
A.LAVILLE
Old June 1st, 2005, 09:44 AM   #2
just_lionel
United States
just_lionel is offline
just_lionel's Avatar
Sounds like it could be power spikes/brown outs and the UPS isn't doing its job. Could be a dead short, could be moisture (our problem at our plant, but it is wet all the time there)
__________________
just_lionel
The sooner you fall behind, the more time you have to catch up.
Old June 1st, 2005, 09:55 AM   #3
TimeFluxCap
Australia
TimeFluxCap is offline
TimeFluxCap's Avatar
Sounds like a UPS fault to me. When was the last time maintenace was performed on the UPS?
Old June 1st, 2005, 10:26 AM   #4
mgvol
United States
mgvol is offline
mgvol's Avatar
If it was a SLC/PLC-5 power supply, was the voltage jumper or selector switch set for the correct supply voltage?
Old June 1st, 2005, 10:37 AM   #5
davidg68124
United States
davidg68124 is offline
davidg68124's Avatar
Good Call mgvol. I was going to suggest looking at the same thing. By default, the ones I have gotten were setup for 220VAC
David
__________________
The PRICE of FREEDOM is not FREE! My son is now a United States Marine and I could not be more proud of what he and others will do to protect our freedoms here at home.
Old June 1st, 2005, 11:32 AM   #6
Johnny T
United Kingdom
Johnny T is offline
Johnny T's Avatar
A long shot... but if you got the new PS card from your stores, it could be a bad batch of cards... I've seen this with a bad batch of inverters once whereby an inverter was dying at a rate of around one a week... Power supplies etc were investigated but it ended up being a bad batch of components in the inverters.
Could possibly be the same thing with your Power Supply although as I mentioned, its a long shot...
Is there any other equipment that is suffering or is it isolated to that one rack?
__________________
I'm beta testing life...
Old June 1st, 2005, 12:32 PM   #7
Ron Beaufort
United States
Ron Beaufort is offline
Ron Beaufort's Avatar
a couple of extra straws to grasp at ...
I’d bet (pocket change only) that the UPS is the culprit ... but just for general ideas ...
have you checked to make sure that the power supply isn’t overloaded by too many modules, etc.? ...
are you using the 24VDC output screws on the front of the PLC power supply? ... if so, make sure that the load on that auxiliary circuit isn’t too high ... and also, check to make sure that the load on that circuit isn’t “spiking” back into the power supply ... think: inductive load being turned on and off ... compare with ignition coil on car engine ... 12VDC input from a car battery gives more than 20,000 volts output to fire the spark plugs ...
also check to make sure the chassis doesn’t have trash (metal filings, etc.) shorting out the backplane ...
and if you have another similar system on hand, there’s always the Fred Flintstone approach to troubleshooting a problem like this ... try swapping various parts (chassis, modules, etc.) from one system to another and see where the problem shows up next time ... (loud groan from audience) ... “swapping parts to troubleshoot?” ... yeah, I know it ain’t glamorous - but sometimes it’s the best way to nail a problem like this ...
PS Edit: whatEVER it turns out to be, PLEASE come back and tell us ... we all like to learn something new from time to time ...
__________________
2-B ?
Best regards, ----+----] [----+------------( )----
Ron | |
PLC Training Boot Camp | 2-B |
I once was lost, but now am found, was blind, but now I see.
Old June 1st, 2005, 06:01 PM   #8
Rod
United States
Rod is offline
Rod's Avatar
I use component swapping. If you have a stereo amp and one channel is out then comparison is appropriate.
If you have two identical production machines and you swap parts you could put trash the machine that is in production.
That's diagnostics.
Rod (The CNC Dude)
Old September 8th, 2005, 09:49 AM   #9
Jdesena
United States
Jdesena is offline
Lightbulb Plc 1760l12awa
Hello All,
I am new here. I am a student at a local junior college taking PLC classes. I just bought for my own learning a PLC 1760L12AWA from AB. I need the interface cable for programming. The cable cost anywhere from $68.00 to $75.00 US. Is there another way to get a generic or compatible cable for this unit? Where can I get the specs of this cable?
PLs help.
Thank you
Joe
Old September 8th, 2005, 11:11 AM   #10
TConnolly
United States
TConnolly is offline
TConnolly's Avatar
I've seen something similar.
If its the same problem we had then it might not be the power supply. We had a rack go bad once. The power supply appeared to go dead so we swapped it out. With the new power supply installed, the PLC blinked on, then went dead. So we took the new power supply over to the bench and connected it to a test rack on the bench and it worked fine. Then we connected the old power supply to the test rack and it worked fine, so it wasn't the power supply. So we figured a card was pulling the system down so one by one we unplugged each module and turned it on. Nothing. The only thing left was the rack, and when we swapped it out, viola, it worked.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Freeware to read an Allen Bradley plc file NewGuy LIVE PLC Questions And Answers 97 November 14th, 2012 06:31 PM
Allen Bradley 1746-BTM ChuckM LIVE PLC Questions And Answers 20 January 28th, 2008 07:16 AM
Allen Bradley PLC 2 Communications hitesh LIVE PLC Questions And Answers 3 August 10th, 2005 05:13 AM
Allen Bradley 1771-CFM or PLC fast input module? ckchew666 LIVE PLC Questions And Answers 17 March 4th, 2005 03:29 AM
Allen Bradley SLC5/04 PLC..I need info bluesman70 LIVE PLC Questions And Answers 3 August 6th, 2004 09:08 AM
