"Alstom" Alspa C80-35 PLC
The "Alsthom" PLC is identical to GE-Fanuc series 90-30. See GE's pages and you will find much more information.
Too program them, you needed a DOS software named LM (logicMaster?) 90. You could do only ladder. There may be a more "modern" Windows tool now.
Yes it is the GE 90-30...
The Alstom 80-35 is indeed the same as the GE 90-30's. I have used the new GE Cimplicity Machine Edition to program them, but it doesn't support the protocols used by Alstom, such as the configuration and setup of the FIP modules. Alstom does have software for it as well called P80-Workbench which we use as well. I believe it is a copy of GE Cimplicity Control???? Hope this helps.
Andrew Evenson
Hi Andrew Evenson,
I am natarajan.i working as plc based panel designer & programmer.Now i am in the position to expand the i/o's of existing Alatom PLC using GE Fanuc Versamax I/O modules. The existing logic is programmed in Alsfa P80 software. I am familiar in GE Fanuc versapro and logic developer programming. can you give solution for my requirement.
Thanks in Advance
Natarajan
Natarajan,
I don't know if the P80 Workbench software supports the VersaMax I/O. If I were you I would try and setup a test PLC to experiment with. I also don't know if VersaPro supports the communication modules or fieldbuses that Alstom uses (e.g WorldFip,N80 bus). If you end up using VersaPro, you might have to configure some of the modules with the handheld programmer. If all else fails, you could contact Converteam(formally Alstom Power Conversion)
Hope this helps,
Andrew
I received a email from a customer looking to support their Alstom Alspa PLC's I think GE bought them, my customer is wondering.... Guessing I...
2,248
hi everyone, i need help of comunity, need "The controlcad 4.1.2" or any other up version, because my copy its corrup and the laptop with the hard...
908
Hi All, I have an old XP laptop that has Controcad for GE/Alstoms P320 AVR. The laptop is on its last legs and we don't have the installation...
2,785
I was wondering if anyone has ever had any success in integrating devices running the courier protocol (Alstom IEC870) into either Rockwell or...
1,400
Hi- just wondering if anyone has had any dealings with the Alstom Courier protocol. I am looking at a legacy project which has a variety of...
2,068
