plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 15th, 2002, 02:29 PM   #1
ganutenator
United States
ganutenator is offline
ganutenator's Avatar
PLC 5 password
I was trying to open a password protected program (that I had worked on at a former employer) but had forgotten the password.
It turns out, that I was able to open the .RSP file in Notepad and saw the password at the very end of the file.
-Just thought this info could help someone.
Does this trick work for other versions and maybe the SLC?
Old November 19th, 2002, 11:59 AM   #2
sly
Guest
Posts: n/a
allen bradley backdoor password is ******** work with every plc
Old November 19th, 2002, 12:01 PM   #3
sly
Guest
Posts: n/a
Old November 19th, 2002, 01:06 PM   #4
Kmitch
United States
Kmitch is offline
The ******** works for SLC. Thanks Sly.
Keith
Old November 19th, 2002, 01:25 PM   #5
SLaubach
United States
SLaubach is offline
SLaubach's Avatar
i cant get ******** to work on a micrologix?
Old January 23rd, 2006, 01:24 AM   #6
John Gaunt
Australia
John Gaunt is offline
John Gaunt's Avatar
Arrow AB Micrologic Locked
I have a customer with a Microloxic PLC that
is password protected. The original supplier
doesn't want to help as the staff have left.
Anybody know the BACKDOOR password for Micrologic.
Thanks...........John Gaunt
Old January 25th, 2006, 07:44 PM   #7
SLaubach
United States
SLaubach is offline
SLaubach's Avatar
**i think that works******
Old January 27th, 2006, 07:36 AM   #8
CONTROLTESTGUY
United States
CONTROLTESTGUY is offline
1761 L32 BWA MicroLogix 1000 Password
I also have a Micro 1000 that I'm trying to break the password. I don't have the original offline file though.
If I start a new file in RS500, I do see the password in Notepad when I open the file. However, when I go to download the file to the CPU, it asks for another 'password' or a 'Master Password'. I tried the above mentioned methods with no luck.
Am I reading the above threads right? I'm entering 8 *'s in the password field. I've also tried other combo's like 8 eights, 10 8's, etc.
There must be a back door in. Any other suggestions.
Thanks for the help,
CTG
Old January 27th, 2006, 09:31 AM   #9
CONTROLTESTGUY
United States
Correction: I was able to reset the password in the Micro 1000 by opening RS500 and trying to go online directly and entering the appropriate password as seen on the AB Knowledge Base.
Thanks for the help.
CTG
__________________
Thanks,
CTG
Old January 27th, 2006, 06:11 PM   #10
tom_stalcup
United States
tom_stalcup is offline
tom_stalcup's Avatar
Just thought I'd clarify something for you.....
The forum doesn't allow password bypasses, copy protection bypasses, and other such things to be posted in the forum. The original poster didn't put in eight astericks..... The posts all most likely originally showed the actual password, and posts were edited to remove the information.
__________________
"If beating your head against the wall doesn't work, try banging a little harder. It won't help you any, but at least I'll be amused"
Old January 27th, 2006, 07:23 PM   #11
Fred Raud
United States
Fred Raud is offline
yeah,,i noticed when i put my atm PIN up it was all asterisked out as well,,i guess its for my safety!!
Fred Raud
ps,,its ****,,dont take all my money,,LOL
__________________
Dont help others because others have helped you,,help others because its the right thing to do!!!
Old January 28th, 2006, 12:13 PM   #12
Ron Beaufort
United States
Ron Beaufort is offline
Ron Beaufort's Avatar
just to clear up a possible misconception ...
Greetings CONTROLTESTGUY,
you said:
my question is this:
did you actually-really-and-truly "reset" just the password - and preserve the existing program? ...
or did you (more likely) clear out the old program AND the password by resetting the whole MicroLogix back to its "factory-fresh-off-the-shelf-unprogrammed-nothing-at-all-in-it" condition? ...
the consensus of opinion is that there is NO WAY to “clear/reset/work-around/backdoor/defeat/cheat” just the password on a MicroLogix while preserving the existing program at the same time ...
specifically, if someone has put a password on a MicroLogix and you don't know the password, then all that you can do is (a) throw the thing away and start over from scratch ... or (b) clear out the password AND the existing program all at the same time ...
the information contained in this Allen-Bradley technote is NOT considered “secret information” ... it is publicly available on Allen-Bradley’s Knowledgebase site ... BUT ... when and if you use it, it will always clear the entire contents of the MicroLogix (existing program and all) - and not just “reset” the password ...
or at least that’s the way that I understand the story ...
__________________
2-B ?
Best regards, ----+----] [----+------------( )----
Ron | |
PLC Training Boot Camp | 2-B |
I once was lost, but now am found, was blind, but now I see.
Old January 28th, 2006, 08:20 PM   #13
SLaubach
United States
SLaubach is offline
SLaubach's Avatar
so you are saying ( edited by phil....again ) doesnt work?
Old January 28th, 2006, 11:57 PM   #14
Alfred
Australia
Alfred is offline
Logic tells me there MUST be a backdoor. Nobody is so stupid to design something he cant controll in any circumstance unless it is encryption of data for secretnis.
Old January 29th, 2006, 07:11 AM   #15
10baseT
United Kingdom
10baseT is offline
It could also be said that nobody is so stupid as to use a password if one isn't necessary (or forget it after they have used it) .
Alfred , there are many things that are just plain stupid , but the facility to password protect a processor against possible fiddling by a load of numbnutz just isn't one of them .
There are backdoors in to a few processors , but you may have gathered that you won't get them here !
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
MPI comunication Manuel Raposo LIVE PLC Questions And Answers 22 July 16th, 2007 06:24 AM
Real World Problem Vietnam Bob LIVE PLC Questions And Answers 8 November 23rd, 2002 02:03 PM
Password in Micrologix1200 AB PLC krunalc LIVE PLC Questions And Answers 6 September 1st, 2002 09:33 AM
