plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old July 12th, 2005, 06:49 AM   #1
Sparks
United Kingdom
Sparks is offline
Siemens IEC Timer
Hi all, is it possible to compare the Elapsed time from an iec timer (SF4) with another value using a compare block.
Old July 12th, 2005, 07:06 AM   #2
dchartier
Canada
dchartier is offline
hello Sparks;
I don't have Step 7 available now, so I am basing my answer to this statement from Siemens' website:
Quote:
How can you calculate times?
ANSWER:
The IEC TIME format is a double-integer format type and can therefore be calculated with normal arithmetic.
A TIME variable is equivalent to the number of milliseconds you want to represent; that is,
[TIME] T#1s == {DINT] L#1000
So yes, you should ne able to compare the value of expired time (attributed to a MDxx variable, for example) of the IEC ttimer with a DINT value.
Hope this helps,
Daniel Chartier
Old July 13th, 2005, 10:01 AM   #3
JesperMP
Denmark
JesperMP is online now
JesperMP's Avatar
The problem is that the comparing DINTs with TIMEs isnt allowed in LAD or FBD when typechecking is on (and it SHOULD be on !).
Do it in STL.
There is no typechecking in STL, so you can do it with no problems.
Here is how to:
Create the compare network in LAD as normal, and specify two DINTs for the compare block.
Switch to STL and exchange one of the DINTs for the TIME variable.
When switching back to LAD, the "offending" rung will remain in STL.
__________________
Jesper
3 strikes and you're out
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Siemens S5 Retentive Timer advocar LIVE PLC Questions And Answers 8 April 21st, 2011 06:15 AM
S7 IEC timer preset from MP panel jtpetersen LIVE PLC Questions And Answers 2 July 6th, 2005 03:28 PM
S7 IEC timer - RESET functionality. JesperMP LIVE PLC Questions And Answers 6 May 28th, 2004 03:26 AM
How to initialise S7 IEC timer ? JesperMP LIVE PLC Questions And Answers 5 May 21st, 2004 09:18 AM
Siemens S7 Timer Questions GTX LIVE PLC Questions And Answers 6 April 30th, 2004 09:55 AM
