plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old November 24th, 2002, 09:54 AM   #1
fbeduhn
United States
fbeduhn is offline
Function Block Diagram Programing
First time on:
I need to program a couple of AB ControlLogix 5550 PLC's with (FBD) function block diagram programs/. I have never programed a ControlLogix let alone in FBD. Help...Where can I learn to program FBD, fast?
Old November 24th, 2002, 12:19 PM   #2
berni
Guest
Posts: n/a
FBD
Witch FBD you don't understand?
You can learn about many of FBD in the help of RS5000 software.
click Help, choose instruction help and choose the function block you want learn
Old November 24th, 2002, 02:12 PM   #3
Gerry
New Zealand
Gerry is offline
Horses for courses
If you have mathematical functions to implement or advanced loop control, then FBD offers some very powerful features. On the other hand, if you're doing AND - OR logic and sequencing, I'd say forget it except as an academic exercise and stick to ladder. The diagrams can very quickly get large and unwieldy for only minor functionality.
The last time I checked, there was no on-line editing capability for FBD's.
Old November 24th, 2002, 08:45 PM   #4
kkgo
Singapore
kkgo is offline
You should really start from the beginning
I strongly suggest that if you do not have any experience with the ControlLogix (Or any of the Logix based processors)
You should go through the basic first. Many people made the mistake of assuming the ControlLogix has the same memory structures, ladder scan cycle, etc... as the PLC5/SLC500... but it is a totally different animal altogether.
For example...
... There will be a limitation on their "connections" to I/O modules, depending if it is an Analog, Diagnostic, optimized rack, etc.
... There is a feature in RSLinx that will optimized your OPC packets, and if you start editing the tags on line (e.g. changing from BIN to INT) You will probably get into trouble.
... It's best to use Arrays and the "User Defined Tags" to lower the comms between your PLC and MMI...
I can't list them all down, (Or even remember them all...) But there is a RSLinx/ControlLogix optimization tips document, that AB would suggest you read through... I don't think that reading through it is an option. I think you must look through it before you start you program. (I can't remember the document name. But the sales guy that serve you should know it... I hope))
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Simulating function block programs ksoundar LIVE PLC Questions And Answers 1 April 21st, 2004 02:33 AM
Function Block with RS Logix 5000 amgc5 LIVE PLC Questions And Answers 3 February 29th, 2004 03:45 AM
what is the function Of TP Block m_abd_el_khalik LIVE PLC Questions And Answers 3 November 10th, 2003 06:37 PM
Need help with making 'integrator' function block? IanJohnston LIVE PLC Questions And Answers 4 June 13th, 2003 11:19 AM
ControLogix PLC Function Block Diagram programming wesley szymczyk LIVE PLC Questions And Answers 3 April 24th, 2003 12:49 PM
