plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old September 5th, 2005, 08:02 AM   #1
hashem
United States
hashem is offline
Water meter & PLC
I have water meter equiped with optoelectronic pulser as follow:
Switch type: IR reflex light barrier to DIN 19234; plug-in design
Switch voltage: 8.2 VDC
Switch current: < 1.2 mA
Quiescent current: > 2.1 mA
Can I wire the pulser output directly to PLC input 24VDC?
Any suggestion will be appreciated.
Old September 5th, 2005, 09:16 AM   #2
randylud
United States
randylud is offline
randylud's Avatar
24V dc
1746-IB8 Input 8 Current Sinking DC Input 19
24V dc
1746-IB16 Input 16 Current Sinking DC Input 19
24V dc
1746-IB32(1) Input 32 Current Sinking DC Input 19
24V dc
1746-ITB16 Input 16 Fast Response DC Sinking Input 19
24V dc
1746-IV8 Input 8 Current Sourcing DC Input 22
24V dc
1746-IV16 Input 16 Current Sourcing DC Input 22
24V dc
1746-IV32(1) Input 32 Current Sourcing DC Input 22
24V dc
1746-ITV16 Input 16 Fast Response DC Sourcing
Specification Catalog Number
1746-IB8 1746-IB16
(RTB)
1746-ITB16
(RTB)
(Fast Response)
1746-IB32
(1)
Voltage Category
24V dc sink
Operating Voltage
10 to 30V dc sink 15 to 30V dc at 50C sink
15 to 26.4V dc at 60
C sink
Number of Inputs
8 16 16 32
Points per Common
8 16 16 8
Backplane
Current Draw
5V dc
0.050A 0.085A 0.085A 0.050A
24V dc
0.0A 0.0A 0.0A 0.0A
Signal Delay (max.)
on = 8 ms
off = 8 ms
on = 8 ms
off = 8 ms
on = 0.3 ms
(2)
off = 0.5 ms
on = 3 ms
off = 3 ms
Off-State Voltage (max.)
5V dc 5V dc 5V dc 5V dc
Off-State Current (max.)
1 mA 1 mA 1.5 mA 1.6 mA
Nominal Input Current
8 mA at 24V dc
Specs are the answer my friend, you can get them for all of the AB discrete I/O modules by going to AB.com and looking them up. If you are using some other brand, then do the same thing on their site. As you can see, the switching voltage ranges for these 24V modules would not suit your 8.2VDC device. Maybe another module would be more appropriate?
__________________
Thunder is good, thunder is impressive; but it is lightning that does the work!
Mark Twain-8/28/1908
Old September 6th, 2005, 07:16 AM   #3
hashem
United States
hashem is offline
Thank you randylud.
Anyone could give me informatin source regarding IR reflex light barrier to DIN 19234 (namur)?
Thank you in advance.
Old September 6th, 2005, 08:31 AM   #4
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
It is an "Optoelectronic IR reflex light barrier".
But the voltage and current specs seems to indicate that it mimics a NAMUR type sensor.
So you need a NAMUR/DC converter to get the signal into the PLC.
__________________
Jesper
3 strikes and you're out
Old September 7th, 2005, 06:53 AM   #5
hashem
United States
hashem is offline
Thank you JesperMP.
Anybody know device that could convert from NAMUR level to PLC 24VDC logic?
With thanks.
Old September 7th, 2005, 07:05 AM   #6
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
PR Electronics has the 2288 module that converts/isolates between many different signal levels incl. NAMUR. I use it myself.
There is an additional nifty "pulse stretching" function that may be useful if the impulse from the sensor is so short that the PLC cannot pick it up.
Tip: Put the converter locally in a terminal box if the cable runs are very long. Otherwise it will pick up noise and convert it to false signals.
__________________
Jesper
Old September 7th, 2005, 11:16 AM   #7
hashem
United States
hashem is offline
Thank you JesperMP again.
Cause you deal with this kind of sensor, can I wire the sensor as the attached image?
Old September 8th, 2005, 02:19 AM   #8
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
I never try to do like that. From where did you get that diagram ?
I know that NAMUR defines a supply voltage (8.2V) and OFF and ON levels in current (1.2mA and 2.1mA).
I guess that the diagram applies to a particular kind of PLC input card. I doubt that it will work everywhere.
Some counter inputs will accept a NAMUR sensor directly.
__________________
Jesper
Old September 9th, 2005, 05:00 PM   #9
hashem
United States
hashem is offline
Jesper,
The diagram was drawn by me, it is for any traditional 12-24VDC PLC input which has the following specifications:
ON Current/Voltage Level: >5mA/10VDC
OFF Current/Voltage Level: <0.5mA/<2VDC
From the diagram: 24V=8.2V+10V+5mA*R
R=1.16K
IOW, R will achieve ON current>2.1mA and 8.2V
I am not satisfied if it will work or may damage the sensor and/or PLC input!
What is your opinion and advice.
With thanks
Old September 13th, 2005, 06:35 AM   #10
JesperMP
Denmark
JesperMP is offline
JesperMP's Avatar
hashem,
I have absolutely no idea if it will work or not.
I would not waste any time but get an signal conditioner that is designed to do the job.
But I am not you.
__________________
Jesper
Old September 13th, 2005, 07:27 AM   #11
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Hashem, In a circuit designed like that, wouldn't you have to consider the input impedance of the PLC card in the calculation for R1?
Old September 13th, 2005, 08:44 AM   #12
hashem
United States
hashem is offline
Thank you OkiePC,
The PLC input as the following diagram still work ON/OFF logically.
I am not satisfied if I add the pulser it will work or may damage the sensor and/or PLC input!
PLC input impedance: 1.8K @12-24VDC
With thanks
Old September 13th, 2005, 09:00 AM   #13
hashem
United States
hashem is offline
Sorry! the diagram is:
Old September 13th, 2005, 10:11 AM   #14
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
I agree with Jesper. Get a signal isolator/conditioner designed for your sensor. I don't think a simple voltage divider circuit will do what you intend without risk to the sensor.
Old April 29th, 2013, 11:56 PM   #15
boxofrelays
United States
boxofrelays is offline
boxofrelays's Avatar
Here's a link discussing signal isolation to a NAMUR standard signal
LINK to Tekron
If you're device is in a hazardous area, then use intrinsically safe barriers that limits the current going to the sensor.
Non-hazardous? You can use a simple non-isolating interface by using a single, general purpose, 2N2222 transistor to interface an 8-volt NAMUR device and connect directly to a 24-volt PLC input.
Here is a good resource on simple transistor circuits:
LINK PCB Heaven
Hope this helps.
-Chris
__________________
Systems Integration Group, Inc.
Kailua, Hawaii 96734
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
PC to PLC Protocol TheRixta LIVE PLC Questions And Answers 13 December 17th, 2008 12:56 PM
Simulator, Simulation, Shadow Code Terry Woods LIVE PLC Questions And Answers 1 January 2nd, 2005 01:40 PM
PLC to PLC Communication (Mitsubishi FX2N) c0met LIVE PLC Questions And Answers 6 May 31st, 2004 07:31 PM
plc for prover meter emegawe LIVE PLC Questions And Answers 1 September 12th, 2003 07:38 PM
PLC hook up check LIVE PLC Questions And Answers 10 July 31st, 2003 01:26 AM
