This board is for PLC Related Q&A ONLY. Please DON'T use it for advertising, etc. |
#1 |
Koyo/ Automation Direct I/o
I AM MESSING AROUND WITH A KOYO/AUTOMATION DIRECT I/O CHASSIS(A 205) IT HAS A 16 PT. INPUT MODULE AND A 12 PT. OUTPUT MODULE. I AM COMMUNICATING TO A H2-EBC EITHERNET MODULE. I AM ALSO USING ENTIVITY VLC TO CREATE LADDER TO TEST. MY PROBLEM IS THAT I SEEM TO HAVE EVERYTHING SET UP AND WHEN I PUT 24V ON AN INPUT TERMINAL THE INPUT LIGHT ON THE MODULE COMES ON BUT NO CHANGES IN THE SOFTWARE(IE. COLOR CHANGE OR VALUE CHANGE 1 OR 0. I AM COMPILEING THE PROGRAM AND THEN I LOAD AND GO, THEN TRY TO MONITOR IN THE MANTINANCE MODE, BUT NO CHANGES. ANY SUGGESTIONS APPRECIATED.
#2 |
Just an idea... Is the PLC in "RUN" mode?...
I'm not familiar with Entivity software... I use DirectSOFT beerchug -Eric |
#3 |
I haven’t used Entivity VLC but I use Entivity Studio. In Studio using Connectivity Center you have to connect, and then scan the I/O to see a change in state on the PC. If you go to Entivity's web site you can go to the eAnswers section do a search for your problem, or you could post your question there. They usually respond to you fairly quickly.
Hope this helps. |
#4 |
![]() Join Date: Sep 2002
Or is the ALL STATUS ON in Debug menu checked?
__________________
Alexandra |
#5 |
I GOT IT
OK HERE IS THE DEAL . THE SIMULATION BOX WAS CHECKED( IN THE DRIVER EDITOR ,I UNCHECKED IT).
THE MODULES WERE CONFIGURED IN THE WRONG SLOTS. IT IS A 6 SLOT CHASSIS. THE FIRST POSITION IS NOT COUNTED( REGARDLESS IF IT IS A CPU OR EITHERNET MODULE ). THEN YOU START COUNTING SLOTS STARTING WITH 1 AND ENDING WITH 5 (WITH A 6 SLOT CHASSIS). THANKS FOR THE RESPONSE'S.. |
#6 |
Glad to hear you got it...
In the future, don't think of the first slot (the CPU slot) as "mot being counted"... Think of it as "Slot 0 (zero)" beerchug -Eric |
#7 |
MISTAKE
I WAS INCORRECT. THE FIRST SLOT IS NOT COUNTED (CPU OR EITHERNET MODULE). THE NEXT SLOT STARTS AT 0 THEN THE CHASSIS ENDS IN 4 (IT'S A 6 SLOT CHASSIS). THE INPUT AND OUTPUT MODULES ARE LOCATED IN SLOTS 0 AND 1. I KEPT PUTING THEM IN AS 1 AND 2. APPERENTLY THE CPU/E NET MODULE SLOT IS NOT EVEN COUNTED AS A ZERO. THANKS
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| Controllogix | elledge | LIVE PLC Questions And Answers | 42 | January 21st, 2005 06:05 PM |
| Automation Direct DL06 | Steve Etter | LIVE PLC Questions And Answers | 28 | January 21st, 2005 07:48 AM |
| Direct Logic Plc's (automation direct) | Johnny Rotten | LIVE PLC Questions And Answers | 28 | January 11th, 2005 06:58 PM |
| Using Lookout and Automation Direct plc's | Rmiller | LIVE PLC Questions And Answers | 6 | March 25th, 2003 08:13 AM |
| koyo (automation direct) help | mrdmrd | LIVE PLC Questions And Answers | 2 | December 2nd, 2002 08:37 PM |
