plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old October 7th, 2005, 09:09 AM   #1
JIMCON
Sweden
JIMCON is offline
Mitsubishi A1SH program transfer problems
Hello.
Im trying to download my PLC program from Gx Developer to a mitsubishi A1SH controller. But i dont manage to establish connection with the PLC.
I have transfered programs to a A1SH before but then it was another program transfer cable. The cable i used before was equipped with an RS-232 to PS2. But this PLC has got an RS 422 i think.. looks exact the same as an printer cable..
I wonder if someone knows something about this. What cable shall i use to transfer the prgram..
Old October 7th, 2005, 09:38 AM   #2
panic mode
Canada
panic mode is offline
panic mode's Avatar
you need SC09 cable
http://forum.mrplc.com/index.php?act...e=post&id=2115
Old October 7th, 2005, 10:36 AM   #3
JIMCON
Sweden
JIMCON is offline
ok thanx.. I think i got one of those..
but i discovered that somethings missing on the CPU i think its the Eprom casette.
or is it possible to run with out it.. ?
Old October 7th, 2005, 11:33 AM   #4
Steve Etter
United States
Steve Etter is offline
Steve Etter's Avatar
None of our A1SH CPUs have Eprom cassettes.
What software are you using and have you checked transfer settings?
Steve
Old October 7th, 2005, 12:55 PM   #5
JIMCON
Sweden
JIMCON is offline
Im using GX IEC DEVELOPER. Ive also discovered that the LED light says "ERROR" hmm ??? what could this be. maybe just some old program that is in the eprom..
Old October 7th, 2005, 01:18 PM   #6
Steve Etter
United States
Ok, if you haven't tried this yet, fire up GX Developer and start a new project (Project -> New Project). On the new project screen, select "ACPU" for the PLC Series and "A1SH" for the PLC Type and click on "OK".
Then, on toolbar of the new project you have created, click on Online->Transfer Setup. This will bring up the Connection Setup Screen. On this screen, make sure the three left-most boxes in each category are selected (Serial, PLC Module, and No Specification). With your SC09 cable attached between the serial port on your laptop and the RS422 port on the CPU, press the Connection Test button on the Connection Setup Screen.
If you have a good cable, CPU, and Com Port, you should have a connection.
Steve
Old October 9th, 2005, 06:43 AM   #7
JIMCON
Sweden
JIMCON is offline
ok thanx.. ill try this..
Old October 9th, 2005, 08:46 AM   #8
JIMCON
Sweden
JIMCON is offline
I found what the problem was. I measured the cable that i thought was a SC-09 and found out that it was´nt
But anyway, tank u all for the help
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Help with a Mitsubishi program command bob1371 LIVE PLC Questions And Answers 2 August 5th, 2005 09:02 AM
Citect and mitsubishi A1SH Dariusch LIVE PLC Questions And Answers 0 May 29th, 2005 09:44 AM
Im having problems with a program pt 1. arosenbach LIVE PLC Questions And Answers 3 October 29th, 2003 03:33 PM
Mitsubushi Fx program problems monkworm LIVE PLC Questions And Answers 9 June 25th, 2003 05:17 PM
Mitsubishi problems gunther LIVE PLC Questions And Answers 12 June 10th, 2003 04:03 AM
